Rare 88 GTA Notchback?
Car: '88 GTA Notchback
Engine: LB9 5.0l TPI
Axle/Gears: BorgWarner 3.45
Howdy,
just a week ago I bought a pretty loaded 88 GTA Notchback. Now I am trying to find out just how many 5-speed Notchbacks were produced.
To get you started, here are my RPOs, in essence:
-Notchback
-T-Tops
-5.0 HO 5-speed w/ 3.45 gears
-digital dash
-UQ7 performance sound w/ subwoofers
-leather
Is there any option my GTA is missing that was available in 88?
Here we go with pics:
http://gehrs.info/bo/DSC00005.JPG
http://gehrs.info/bo/DSC00006.JPG
http://gehrs.info/bo/DSC00007.JPG
http://gehrs.info/bo/DSC00009.JPG
-Notchback
-T-Tops
-digital dash
-leather
AAA STANDARD EQUIPMENT
AA8 WINDOW, R/CMPT LID (NOTCHBACK OPTION!!!)
AK1 DELUXE BELT AND SHOULDER HARNESS
AK1 RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AM9 SEAT, RR, SPLIT, BACK, FLDG
AQ9 SEAT, FRT PASS A DRIV, RECL
AQ9 SEAT, FRT BKT PASS DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW, TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, SIDE
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 ORNAMENTATION, INTR, DR MAP POCKETS
BV3 ORNAMENTATION, INTR, I/P, BLACK
BY4 ORNAMENTATION, INTR, INST PANEL, NAME PLATE
B20 ORNAMENTATION, INTR, LUXURY
B34 COVERING, FRT FLOOR MATS CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
B67 CONTAINER, RADIO CASSETTE TAPES
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CD2 INDICATOR, WSWA JAR FLUID
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C49 DEFOGGER, RR WINDOW, ELECTRIC
C67 HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS
DE4 SUNSHADE, REMOVEABLE HATCH ROOF
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D34 MIRROR I/S, SUNSHADE
D5T GEAR, SPEEDO DRIVEN
D80 SPOILER, RR END PNL
D9E SENSOR, VEH SPD
E5Z SPEEDOMETER ADAPTER (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GM3 AXLE REAR, 3.45 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, ENG OIL
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 GENERATOR,105 AMP
LB9 ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NK4 STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS
N33 STEERING COLUMN, TILT TYPE
N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
PB4 LOCK CONTROL, WHEEL
PW7 WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 LAMP, GROUP
T93 LAMP, TAIL & STOP, SPECIAL
T96 LAMP, FOG
UA6 THEFT DETERENT SYS
UF6 LAMP, INTR, CONSOLE, COURTESY
UK3 ELECTRONIC SYSTEM, ACCESSORY CONT
UQ1 RADIO PROVISIONS, FOR STEREO
UQ7 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER, SUBWOOFER
UT1 TONE GENERATOR, WARNING
UT4 RADIO, AM/FM-ST CASS, AUTO NR, TOUCH CONTROL, STEERING WHL CONTROL
UW1 DIAGNOSTIC SYSTEM
U25 LAMP, INTR, RR COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U52 CLUSTER INST, ELECTRONIC
U75 ANTENNA, POWER, RADIO
VAN ASSEMBLY PLANT, VAN NUYS, CA
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 ANTENNA, FIXED
WDV NEW YORK STATE WARRENTY ENHANCEMENT
WS4 MODEL CONVERSION, TRANS AM
WS6 PERFORMANCE PACKAGE, SPECIAL
WW8 APPEARANCE PACKAGE(BRIGHT RED), AERO #8
W62 ORNAMENTATION, AERO PACKAGE
YS1 SEAT, REAR (CUSTOM)
YT1 BUILD UP DR & QTR
Y84 MERCHANDISED PKG, GTA, TRANS AM
ZV1 MANUFACTURERS STATEMENT OF ORIGIN, WINDOW STICKER
52P WHEEL COLOR, GOLD MET (91)
6ZX SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
66I INTERIOR TRIM, MED BEECHWOOD (91)
662 TRIM COMBINATION, LEATHER, MED BEECHWOOD (91)
669 SEAT BELT COLOR, MED BEECHWOOD (9) (91)
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL COMPUTER SELECTED REAR LEFTHAND SPRING
81Q MOLDING COLOR, BRIGHT RED (91)
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
9NL COMPUTER SELECTED REAR RIGHTHAND SPRING
D9E SENSOR, VEH SPD
TR9 LAMP, GROUP
T96 LAMP, FOG
V73 ANTENNA, FIXED
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Some things to note about the car
1) the car originally came with steering wheel controls, and those are missing, also the radio is obviously not originla
2) the headrests are gray? originally they were the brown/tan
3) the spoiler is someones aftermarket spoiler, almost looks like a Fiero Spoiler,
Its a nice looking car in all however
I think the car came with pretty much all the options in 1988.
Cool find
John
Cool find
John
Should have stated that in the original post: I am going to return this baby to bone-stock, b/c of the value
And how many 5-speed Notchbacks were produced. I know that there were only 624 Notchbacks produced, but how many of them were 5-speed manuals?
You may not find out that information. Unfortunately GM typically did not document the number of cars with each option. The best you could do right now is the number of totals for 1988
MM5 Manual transmissions 9,244
LB9 5.0L TPI Engine 10,379
Frankie Rider is the expert, you may try the GTAsourcepage
John
John
i don't think you will find such, unfortunately. It appears Pontiac kept very poor records. The total Notchback production figures itself is still up in the air to many people. So getting break-downs per option seems even less likely.
On a side note, would 305 5-speed actually be considered an "option"? i know it was available, but i mean, i don't know if it actually could be considered an option above the 350. When i say "option", i mean in the sense as additional options that make the car worth more money (then and now).
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Re: Rare 88 GTA Notchback?
JG1 aluminum driveshaft
By '89, you had to order the notchback from the dealer. '89 TTA's were not available with the hatch, but IF you really wanted one, then the dealer would instal it.
Please correct me if I'm wrong...
-Andrew
RPO code AA8, which means Notchback, which means Factory Option
From GTA Source Page:
" Production records show a total of 625 units were built during 1988 and 1989. The option was actually canceled before the start of production for 1989; a dealer bulletin in August 1988 announced its demise, instructing dealers to recall any and all GTA orders with the Notchback code on them. Still, PMD records show that one single car was built for 1989........ no doubt the car pictured above from the 1989 Pontiac brochure."
Originally posted by kaptinkafeen
Although I am not 100% positive, I thought the notch back roof was a dealer only option - not a true factory option.
-Andrew
-Andrew
As this discussion shows, we probably should start a VIN-database for the Notchbacks including the RPOs, that would give us a better overview. The TTAs have such a database and there were more than twice as many produced than our Notchbacks, so I really think its time to start such a database
Re: Re: Rare 88 GTA Notchback?
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
To my eyes, it appears that this car has every single available option for a 1988 GTA.
The only options available were the 305 engine, the 5-speed transmission, the Notchback decklid, T-tops, the U52 instrumentation, leather trim, and the subwoofer speaker system. The UA6 VATS system was also listed on the window sticker as an option; I can see from the RPOs that this car has it as well. It is said that some early 1988 GTAs do not have it, but I have never seen one.
I have never seen a 1988-model 305 GTA with a aluminum driveshaft either. I have seen later model 305 GTAs equipped with them, but not earlier ones.
That spoiler is pretty extreme.... looks kind of like a factory spoiler on steroids! The radio and steering wheel should not be too hard to find... I have about four of them stashed away in my shop.
Congratulations on a great find!
The spoiler has already gone (is up for sale by the way) and the correct D80 spoiler is about to be installed.
Would you be willing to let one of your radio/steering wheel combos go for the restauration of a fully loaded Notchback?
Car: 1987 GTA 350
Re: Re: Re: Rare 88 GTA Notchback?
I don't think that you could order the JG1 with the 305, as the production numbers on the gtasourcepage.com show that exactly 6,913 JG1s were produced - just as 6,913 L98s were produced. Looks to me like all 350s were equipped with the aluminum drive shaft.
Conrad
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If the radio has been changed out, you might want to make sure that the factory subwoofer setup is in the car as well since you have the option code for it (UQ7 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER, SUBWOOFER) alot of them were removed to put 6x9 speakers in.
I would consider the 305 automatic inferior to the 350, but the 305 manual is something special as in the US factory manuals are pretty rare. At least compared to us in Europe.
He did not say there was a 350 M5....
John
John
Car: 1987 GTA 350
Frankie, does the 305 without an aluminum driveshaft theory apply for the regular TA as well? Because my '88 TA with the 305 has the JG1 option code.
Really?? Why would be ok to order jg1 on a ta but not the top-o line gta? Can you post a pic of the codes? That is strange.
Conrad
Conrad
Conrad
<img src="http://www.gtanotchback.com/misc/88tarpo.jpg">
i don't understand why it would be OK to order it on the regular TA, and not the GTA, either?
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Anybody here got an 1987-1988 GTA with the LB9, MXO, and JG1 codes....?
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
something else i noticed, he has the U75 and V73 RPO codes.
U75 is antenna ,power ,radio.
V73 is antenna fixed. how can he have both?
excuse the half post above, dunno how but my puter decided to hit submit for me before i was finished.
V73 is
That was supposed to be V73 = VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
Strange, I cannot edit my post?
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
