Upper door trim
Old Sep 30, 2005 | 05:27 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Upper door trim
I need the upper door trim for my car. They are the ones on the outside of the door that seal against the window. I will attach a picture to meake sure that you know what I am talking about. Where is the best place to get these from? Thanks.
Old Sep 30, 2005 | 05:29 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
pic
Old Sep 30, 2005 | 05:30 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
crap, pic:
Old Sep 30, 2005 | 10:12 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Here's a link
Hawk's Kit
Old Oct 1, 2005 | 09:26 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
your friendly local GM dealer. cost me 86 bucks for both sides and they had em for me next day.
matt
Old Oct 1, 2005 | 04:01 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I bought mine from 1A Auto and they fit like crap.
Old Oct 1, 2005 | 05:37 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Thanks guys. The new Ttop rubbers kinda highlight the sucky door seals... Are the Hawks really GM parts? I don't think things that don't fit. Got a new GM front and it went on great. Aftermarket high rise spoiler... kinda a 1/4 inch not wide enough. Cracked, had to reglass it.
Old Oct 4, 2005 | 12:11 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
matt
Do you have the PN for the driver and passanger side?
Kevin
Old Oct 4, 2005 | 08:45 PM
i dont off hand. i did but i lost it. ill check my crash book for you tomorrow when i go into work for the number. just give the dealer a call and tell him u need outside belt moldings. hope that helps
matt
Old Oct 4, 2005 | 10:25 PM
Kevin84Z28's Avatar
Aren't they called outside "window sweeps' ?
Old Oct 5, 2005 | 04:36 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
they are called window sweeps.
part numbers are
10124265
10124264
don't know which is which, sorry.
Old Oct 6, 2005 | 01:11 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
23 bucks off of gmpartsdirect.com
not bad!
Old Oct 6, 2005 | 01:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
46.60 for the part 15.01 for S&H. I like it. Thnx. I got a lower nose ground effect for my car and the CAMARO grille from them. Pretty quik service.
Old Oct 7, 2005 | 07:28 PM
Xophertony's Avatar
Axle/Gears: n/a
i have always been impressed. saved me like $100+ on springs
Old Oct 7, 2005 | 10:09 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
They seem to have alot, but you need to do some research to make sure you get the right part. They need product pictures. Besides that, you just can't beat real GM parts.... especially ones at low prices. Someone needs to sticky a link the gmpartsdirect.com site, IMO.
Old Oct 8, 2005 | 10:01 AM
Klortho's Avatar
Car: 1987 GTA
The ones from Hawk's are GM pieces, he puts up if the piece is aftermarket.
Old Oct 8, 2005 | 10:26 AM
FieroGTA's Avatar
Also commonly called "dew-wipes"
Old Oct 8, 2005 | 10:30 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Dew wipes. Mine don't do that too well. Just kind of streak some of it off. While were on the subject of windows, my passenger side won't let the door shut when the window is all the way up. It catches the upper rubber seal and bends the window out. Any idea on how to fix this?
Old Oct 8, 2005 | 09:01 PM
Kevin84Z28's Avatar
Yep, there is a window stop that you have to adjust. Your window is going too far down. Do a search on this site, multitudes have had the same problem. You'll even find some pictures to look at also.
Old Oct 8, 2005 | 09:45 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Kool. Thanks. I guess when I change the upper seal would be a good time to do it, then?
Old Oct 9, 2005 | 07:34 PM
Kevin84Z28's Avatar
Yep, it's a very easy adjustment. But I've seen guys change the outer sweep with out taking the door panel off. To fix the window stop you have to take the door panel off. Have you ever done that? I can walk you through it, done it a million times.
Old Oct 9, 2005 | 07:45 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Ditto to what he said.
Old Oct 9, 2005 | 07:58 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, I could use a walk through for this. I don't want to screw anything up.
Old Oct 9, 2005 | 10:50 PM
Kevin84Z28's Avatar
First do a search on what it is you want to do. It's usually already posted with illustrations. Go to the tech file and search under "removing door panels." if that does not work I write something up for you. It's easy, but of course there is one trick getting the door panel off without tearing from the upper trim.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
