How to verify matching engine on an 89?
Old Oct 26, 2005 | 11:42 PM
TA76's Avatar
Can anyone tell me where to find the VIN number on an 89 L98? I would like to verify that the engine in this car is the one that it came with from the factory.
Thanks!
Old Oct 27, 2005 | 12:08 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, it should be on the block's deck, on the passenger side, right in front of the cylinder head. It will be stamped into the machined surface.
Old Oct 27, 2005 | 08:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Here is what your looking for, it shoudl be behind the AC bracket in 89 on the RH side of the engine.
What your looking for is the last 6 or 7 didgets of the VIN.
JOhn
Old Oct 27, 2005 | 08:43 AM
TA76's Avatar
Thanks guys, that is what I need to know!
Old Oct 27, 2005 | 09:52 AM
okfoz's Avatar
THe question I have is if you look at the VIn on the block its 2HN211943...
I am trying to figure out what the VIN of the car was. Is the first didget "2" the check didget, or does it designate Pontiac...
The HN211943 is prety self explanitory.
John
Old Oct 27, 2005 | 11:26 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
2 = Pontiac
H = 1987 model year
N = Norwood, OH factory
211943 = sequence number
Old Oct 28, 2005 | 07:44 AM
okfoz's Avatar
thats what I was thinking thanks.
John
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
