firebird stats
Old Dec 11, 2005 | 12:44 PM
FireBirdBoy's Avatar
firebird stats
can somebody please help me and tell me the pros and cons of a 82-84 firebird becuase i have one im considering buying but i dont no if i should
Old Dec 11, 2005 | 05:22 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
pros and cons as compared to what? a civic? a dodge duster? a later model firebird?
Old Dec 11, 2005 | 06:03 PM
o yeah sorry i meant to other firebird models
Old Dec 11, 2005 | 06:05 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
What year are you thinking of buying and how much?
Old Dec 12, 2005 | 09:57 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
82 - 84 Firebirds
Pros- THey are less expensive typically to purchase than the later cars, especially 91-92. HO cars are probably the most desirable, the CFI cars are also desirable for the years. An LG4 chasis would make for a nice V8 starting point if you want to build a 350 and transplant it.
Cons - The 82 & 83 CFI was not the most reliable system from sources on this site, although there are several folks with good strong running CFI cars on the boards.. The LG4 was a real Dog, An I4 should stay in a Fiero, and the V6 was not really hot either.
Actually I feel that 3rd gens matured with age, and by the end in 1992 they had probably the best, most reliable cars. I did read that the Fit and finish of 82-86 cars is not as good as 87-92, I have looked at both but not sure why the statement was made.
JOhn
Old Dec 19, 2005 | 07:17 PM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
Originally posted by okfoz
82 - 84 Firebirds
JOhn
Was the LG4 really that bad?
Old Dec 19, 2005 | 07:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yep.
Old Dec 21, 2005 | 07:54 AM
okfoz's Avatar
THe most redeeming thing about the LG4 is the Insurance, its usually cheep for LG4 cars, and then you can put a buig ole 350 or 400 and no one is the wiser... and you cna still afford the insurance.
Actually there is not a whole lot of difference for insurance between LG4 and L98 cars, a little, but every bit helps.
My LB9 is about 20% more and my L98 is about 25% more for insurance. IIRC
John
Old Dec 21, 2005 | 08:12 AM
ajmclean's Avatar
and the handling was improved after 85
Old Dec 21, 2005 | 07:30 PM
cdartz's Avatar
Actually I'd say that an LG4 car that has a nice clean body would be a great buy. It's super simple to replace an LG4 with a 350. I look at an LG4 car as good base to start with. Carb 350 engines are cheap to buy, and the swap is easy. I'd avoid a V6 car, as engine swaps are far more difficult. I went through the V6 to V8 process with my 87, and it was a real pita.
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
