I have a VIN for a 78 TA that i need decoded..
Old Oct 21, 2000 | 06:28 PM
TheKid's Avatar
any help will be appreciated
1990 Firebird
(400+HP 350 still in progress)
Complete custom interior
License Tag `URLOSIN`
Old Oct 21, 2000 | 11:19 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
What is the VIN.....? Post it and I can help you out.
Frankie Rider, 2
The GTA Source Page
1988 GTA Red 5.7L Hatchback
1988 GTA Black 5.7L Notchback
1988 GTA Gunmetal Metallic 5.0L Hatchback
1981 Trans Am WS6 5.0L..... soon to be replaced by Chevy SB400
1980 Turbo 4.9L Trans Am WS6
Old Oct 22, 2000 | 03:50 PM
TheKid's Avatar
Thanx..this is the VIN...
2W87Z8N142241..........
I was told it was a Hurst Trans Am..1 of 1200 or so....but i dont know.
1990 Firebird
Old Oct 22, 2000 | 11:16 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
2W87Z8N142241.......... breaks down as:
2 - Pontiac division, GM
W - Trans Am body series
87 - 2 dr. coupe
Z - 400 ci Pontiac engine (6.6L)
8 - Model Year (1978)
N - Norwood, OH assembly plant
142241 - Consecutive sequence number
As for what the car is, there was no "Hurst Trans Am" built in 1978. The specific codes as far as options and equipment will be stamped on the body tag under the hood at the bottom of the windshield on the LH side. There will be no "coded" mention of a special model in the VIN for 1978 models..... 1979-81 models are a different story.
Give more specific details about the car's appearance and what's printed on the body tag, and I may be able to help you out more.
Frankie Rider, 2
The GTA Source Page
[This message has been edited by FrankieRider2 (edited October 22, 2000).]
Old Oct 23, 2000 | 09:36 AM
TheKid's Avatar
Hey, thanx for all the info..i really appreciate it....im buying the car a week from today for $400. Ill get the numbers off of the body tag then and repost them....the car is actually in damn good shape to have been sitting for 10 years...it has the half-ttops (that just what i call them..they look narrower than than others)..but ill just have to get the numbers for you..he said the car came with a hurst 4 speed transmission but, ill wait and give you those body tag numbers next monday when i get it. thanx again
1990 Firebird
Old Oct 23, 2000 | 04:08 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
From your description, that car has the "Hurst Hatch" T-tops in it. Those tops were factory from GM for 1977 and 1978; the 1978 cars got either Hurst or GM/Fisher tops..... installation of the type was at the factory's discretion.
The Hurst tops are much narrower, have a molding around the outside on top of the car, and have a broader band between them on the roof; they also do not extend to the rear of the door/glass joint like the GM/Fisher tops do. I had a 1981 T/A with Hurst tops installed after production..... and that car leaked like a sieve. You could not stop the water from coming in; nothing helped, resealing, adjusting, you name it, I tried it.....
All the T/As with 4-speeds in 1977-1981 had the Hurst shifter installed, so that is correct for the car.
For more information about your car go to the <A HREF="http://pub12.ezboard.com/b2ndgentransamforum"> 2nd Generation Firebird/TA Message Board</A>. There are a lot of educated folks there who know virtually everything about these cars, and are always willing to help. They always help me.....
Good luck!
Frankie Rider, 2
The GTA Source Page
Old Oct 25, 2000 | 05:43 PM
TheKid's Avatar
Thanx alot bro..ill go to that board and post it after i get the body tag numbers off the car.......thanx again for all your help..peace
1990 Firebird
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Galaxie500XL
Feb 1, 2020 04:53 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
AussieZ28
Sep 30, 2015 03:36 PM
J.C. Denton
Sep 8, 2015 05:35 PM
