What does your parking brake handle look like?
Old Jan 13, 2006 | 07:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I bought a replacement parking brake handle on Ebay and when I swapped it last night, I noticed that it was quite a bit different than my stock one. I thought it might be nice to get feedback from everybody so that we can learn about the various different handles and what years/models they were used on.
I'm aware of the grey leather ones in the firebirds, the black leather ones in the Camaros, and the plain plastic ones that were probably in both. What I find odd though is that the leather on my new one is different than my original. The stitches are much smaller, and there's more of them. The grain and shine of the leather is also very different, though that could be partially due to age and *** knows how much armor all on the original one. What's interesting is that the grain and stitching on the handle should probably match the shift **** and perhaps the steering wheel, and if there's this much variation between model years, it could make a concours restoration very interesting.
Anyway, let's start a poll of sorts by answering the following questions:
1. What year is your car?
2. Camaro or Firebird?
3. Trim level? (SC, IROC, etc)
4. Did your car come with a stock leather steering wheel?
5. Did your car come with a stock leather shift ****?
6. What does your parking brake handle look like?
A. What is the color?
B. Does it have the large or small stitches (if it's leather at all)?
7. Does it attach with a fine thread screw or a self tapping screw?
Attached is the pic of my 2. The bottom one is my original 85 handle. The top one is the one I just bought. You can see that the original has much larger stitches, and though it's hard to tell in this pic, it's also much shinier with a smoother grain to the leather. Another interesting thing is that the new one came with a fine thread machine type screw instead of the self tapping job that held my original in. The machine screw wouldn't work so I had to re-use the self tapping screw.
Attached Thumbnails What does your parking brake handle look like?-ebrake2.jpg
Old Jan 13, 2006 | 11:47 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
My 86 Iroc had a leather wrapped wheel and the leather wrapped automatic shift ****. My e-brake handle is still intact however and it looks identical to your original on the bottom there. I dont have a pic of it but I can tell you without a doubt it is identical to your original. FYI when my car still had the automatic I purchased a leather shift **** from year one and it was exactly like my stock one.
Old Jan 13, 2006 | 04:20 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
ya my 84z28 came with the bottom one also replaced it with a plastic one
Old Jan 13, 2006 | 04:38 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
I have an 89 iroc and it has a handle like the lower one in your pic
is the other one from a bird?
Speed
Old Jan 13, 2006 | 08:13 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
1-1983
2-Camaro
3-Z28 w/Custom Cloth interior4
4-Yes to stock leather steering wheel
5-Yes to stock leather shift ball
6-Like the bottom handle in your pic
6A-Black
6B-Large stitches
7-Fine pitch in first hole of the parking brake metal handle(did you notice there's second hole in the handle?)
Old Jan 22, 2006 | 10:49 AM
Drew's Avatar
Hey Jim,
Can't say as though I've seen one like the top one before... But then I've never looked all that closely. I've got a couple from 83-84 Z28's that all look like the bottom one, same as the one in my 87 Iroc.
The later Firebirds (85-up) all used grey leather, with stitching spaced about the same as the bottom handle.
It's possible that its from an 82-84 Firebird or a later (90-up) Z28, but I'd suspect its either been recovered or its an aftermarket copy or from some other type of vehical.
As for the screw, I've seen both fine thread retaining screws and self tapping. Not sure which goes with which vehical though.
Old Jan 22, 2006 | 12:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
85 IROC with leather steering wheel and leather-covered shift ****, both in black. The handle is like the second one. Unsure about the screw.
JamesC
Old Jan 23, 2006 | 02:10 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
1. 1988
2. Camaro
3. IROC-Z
4. Stock leather steering wheel.
5. Stock leather shift ****.
6. Black leather, like the bottom one pictured.
A. Black
B. Large stitches, same as **** and wheel.
7. Fine thread screw.
Perhaps the one you bought has be recovered?
Old Jan 23, 2006 | 08:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
could one be leather and one vinyl???
Old Jan 23, 2006 | 09:19 AM
Jim85IROC's Avatar
In the case of my 2 handles, both appear to be real leather. It's entirely possible that the one I bought is an aftermarket piece, but I'm not aware of there being any aftermarket repops.
I'm also finding it interesting that most of the guys responding have a machine-thread screw holding theirs in, while mine is a self tapper.
Old Jan 23, 2006 | 09:21 AM
Jim85IROC's Avatar
Here's another pic of the two handles:
Attached Thumbnails What does your parking brake handle look like?-ebrake1.jpg
Old Jan 23, 2006 | 10:03 AM
coolram62's Avatar
Engine: LU5 305 CFI
Jim on your car does the parking brake handle itself have 2 holes drilled in it?And does the self-tapping screw on your's go in the first or second hole(from the release button end)?The machine thread screw on mine goes in the first hole.Could it even come down to what plant the car was built at?Mine is a van Nuys car.
Old Jan 24, 2006 | 03:20 PM
JamesC's Avatar
Where's this one fit:
https://www.thirdgen.org/techbb2/sho...hreadid=342550
JamesC
Old Jan 24, 2006 | 05:01 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: What does your parking brake handle look like?
1. 1986
2. firebird
3. base
4. plastic/vinal steering wheel
5. plastic vinal shiftknob (stick)
A. grey
B. plastic
7. fine thread screw
1. 1988
2. firebird
3. GTA
4. Did your car come with a stock leather steering wheel? yes
5. Did your car come with a stock leather shift ****? automatic, yes
A. black
B. large
7. Does it attach with a fine thread screw or a self tapping screw?... you know... i have never removed it. EDIT fine thread
Old Jan 24, 2006 | 08:23 PM
Drew's Avatar
JamesC
Cavalier, or early 80's Sunbird.
Old Jan 27, 2006 | 10:55 PM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
1. 1987
2. Firebird
3. Trans Am
4. Yes
5. Yes
6. No. 2
A. Grey
B. large
7. No idea- never have removed it
Old Jan 29, 2006 | 01:44 PM
MNformula350's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=343247
Old Jan 29, 2006 | 04:05 PM
Drew's Avatar
I posted a best guess, sorry I didn't make that more clear. Learn something new everyday.
Old Jan 30, 2006 | 07:11 PM
S'ok, I am a continuing thirdgen student as well LOL
Old Feb 7, 2006 | 05:12 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
RE: Parking Brake Handle/MOMO...
I havn't had a chance yet to check if it fits; However, I put a momo parking brake leather handle on my 88 Supra that looks REALLY sharp!
If you run a search on Ebay for MOMO, it probably will pop up, or your local Hot Rod parts shop probably has the momo color catalogue. I did the momo brake, shift handle, pedal, door sills on the Supra and it really gave the car a refined, fresh look. Nitro
Old Feb 8, 2006 | 10:24 AM
Jim85IROC's Avatar
Re: RE: Parking Brake Handle/MOMO...
Um... thanks, but I'm more or less just trying to learn about the stock variables, not the world of the aftermarket.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
