My Convertible hatch release don't work.
Old Apr 22, 2001 | 01:30 AM
camaro 22's Avatar
i posted this in the electronics but got no reply's, and since this is like the convertible board i'll post it here. the power button don't release the hatch. it doesn't do nothing. i don't think it's the switch cause i took the trunk release button out my 89rs and tried it and it still didn't work. anyone have any ideas why? it never worked since i got the car in nov last year.
Old Apr 22, 2001 | 01:50 AM
89RagTopRS's Avatar
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
Just use the manual pulls behind the rear seats to release it. Look at the release mechanisms and see if anything is bent or disconnected.
Another possibility is the connection was cut somewhere along the way.
I've never experienced a problem like that so I'm kinda pulling ideas off the top of my head. Willie is the best source for vert info that I've met here.
1989 Camaro Convertible RS
dark silver w/black top
305tbi, auto, 2.73 posi
SLP exhaust, 16x8 black GTA rims as soon as I get them
Check out Phil's Rice Boy Page
<font face="Verdana, Arial" size="2">Those who wish harm on others are weak souls</font>
Old Apr 22, 2001 | 01:55 AM
camaro 22's Avatar
thank you 89ragtop. another thing i forgot to mention was that when i put the top down, or up at that, the passenger side doesn't catch at all. could it be that the catch is bad on that side and causing that switch not to work right? thanks again.
Old Apr 22, 2001 | 08:08 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My 89RS with electric trunk pull down had a similar problem. There is a ground wire coming from the trunk pull down to the release switch. So the cover will not lift if the trunk lid is up. My ground had come loose back at the trunk pull down.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Apr 22, 2001 | 10:31 AM
89RagTopRS's Avatar
Are your bows bent? Mine are and it makes it very difficult to put the top up or down properly. Most likely its that.
If the catch is bent out of shape, it won't release with the weak power of the release inside the console. You need to put more muscle to release, like in the manual release.
Old Apr 22, 2001 | 02:36 PM
deacon17's Avatar
I would follow Rob P's suggestion first and check out the ground attached to the rear pull down motor. I had the same problem after I got mine painted and they didn't replace the ground wire. The switch wouldn't do anything, not even a spark. So if you're not getting even a clicking noise, check the wiring.
Old Apr 22, 2001 | 03:05 PM
iroc22's Avatar
I had the exact same problem and I pulled out the switch and cleaned all the dust out of it. The dust in the switch maybe stopped the connection. It seems to work okay now.
Old Apr 22, 2001 | 04:49 PM
jm91rs's Avatar
most people have problems with the tonneau cover not coming up because something is bent, but if you aren't getting even a click from your switch, it is a wiring problem or bad switch.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
Old Apr 22, 2001 | 07:11 PM
camaro 22's Avatar
yeah, i'm not getting nothing. guess i'll have to look into it a little deeper. thanks guys.
Old Apr 24, 2001 | 12:27 AM
camaro 22's Avatar
ok, update. i found out why my passenger side wasn't catching. the release lever and cable were stuck all the way to the release position. now, it is still stuck. the cable going into the black tube won't move. like how the tube is connceted to that bracket to keep it from moving so just the cable itself moves in and out. well the cable wont move unless the black cable moves with it. i also noticed that the metal looking tube things on both sides that the wire goes to are rusted. could they be bad or not working? i still am not even getting a clicking noise, nothing.
Old May 7, 2001 | 10:58 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Another two areas to look into. On automatic equipped cars the shifter must be in Park or Neutral for the tonneau to release. If it works in Neutral, but not in Park, tnhen the netral safety switch may need to be adjusted. On T5 eqipped cars the parking brake must be engaged. There is a ground wire going from the tonneau release switch to the parking brake. Good luck, Lon.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old May 8, 2001 | 04:00 AM
camaro 22's Avatar
thanks, i'll check into that. i got the pass side release cable to move now. the canister thing was rusted so sprayed it up with wd40.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
smooth
Aug 18, 2015 06:34 PM
Randomtask2
Aug 13, 2015 01:57 AM
