nine bolt rear?
Old Apr 23, 2001 | 11:09 AM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
nine bolt rear?
Working on my car this past weekend, I noticed that I have a nine bolt rear. I thought I heard that this would indicate that I have the borg warner rear that went out on some thirdgens. Is this true? My car is an 87 iroc, 5.0 TPI 5sp with the G92 package. Thanks.
Old Apr 23, 2001 | 11:34 AM
MikeDwhoROCZImports's Avatar
Yep, borg warner. Being that you have a 5-spd, you might even have 3.45's....
Old Apr 23, 2001 | 12:26 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
More than likely your car will have two tags attached by the cover bolts. One will tell you if its a posi the other will tell you what gear you have.
Old Apr 23, 2001 | 10:27 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
<font face="Verdana, Arial" size="2">Originally posted by MikeDwhoROCZImports:
Yep, borg warner. Being that you have a 5-spd, you might even have 3.45's....</font>
You DO have 3.45's. The 9-bolt Borg Warner was introduced* in 1987 on Camaros on:
1) G92 (3.45) equipped IROC-Z's and
2) L98 IROC-Z's (3.27)
*The 50 prototype 1986 350 IROC-Z's all came with the 9-bolt but cannot be considered the "first" as it was not a regular production vehicle.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Apr 24, 2001 | 12:14 AM
robbob's Avatar
I have an 85 trans am with 9bolt,was it offered in that year and would also be 3.45
Old Apr 24, 2001 | 07:50 AM
Willie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by robbob:
</font>
My previous statement refers to Camaros only.
As for Firebirds, I believe (not confirmed) that the first Firebirds with the 9-bolt rear was 1986. Because the rear gear ratios are slightly different on the 9-bolt as opposed to the 10-bolt, you can easily check the RPO codes to determine which gear ratio originally came on the car. With that info, you can deduce whether it was a 9 or 10-bolt.
9-BOLT
2.77 ?
3.27 GW6
3.45 GM3
10-BOLT
GU2 2.73
GU4 3.08
GU5 3.23
GU6 3.42
Willie
Old Apr 24, 2001 | 12:14 PM
LFN AT U's Avatar
1985 was the first year for 9-bolts in Trans Ams.
Old Apr 24, 2001 | 02:23 PM
Willie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by LFN AT U:
1985 was the first year for 9-bolts in Trans Ams.</font>
In order for me to add this information to my database, I need a some sort of proof. Citing a reference is always good. Even better is someone who shows one of the 9-bolt rear axle ratio code on their 1985 RPO sticker. Anyone?
Willie
Old Apr 24, 2001 | 09:03 PM
Guest
Guest
Posts: n/a
It was 85 for the Firebirds Willie, but I cant document it because the documents went with the car when I sold the POS. Mine had the 2.77. I know it was original, I had all the documentation on the car including the window sticker, and stuff from PHS.
Old Apr 25, 2001 | 12:25 PM
LFN AT U's Avatar
I have documentation showing '85 was the first year. I have owned three '85 Trans Ams with 9-bolt rearends. The '85 GM service manual has the 9-bolt listed with part numbers for each gear.
Old Apr 26, 2001 | 05:11 PM
Tonyrodz's Avatar
Transmission: auto
My 86 T/A(tpi) has a 9 bolt in it. Has the rear disc setup-also has the 3.27's.
My 89 had the same exact setup--disc etc.
Old May 7, 2001 | 03:23 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
<font face="Verdana, Arial" size="2">Originally posted by Willie:
Willie
</font>
Just came across this post. Did you get your proof? Otherwise, I'll be glad to oblige. I have all the original documents that came with my '85 T/A. They clearly show that it has the Borg-Warner diff. I can fax them to you.
-Greg
'85 Trans Am - WS6,TPI:
Original owner, original paint/engine/interior, plus the usual bolt-ons
Old May 7, 2001 | 10:41 PM
ausrs's Avatar
just as a matter of interest where the 9 bolts where made (borg warner ) they where not even aware that they went into camaro,s at all ..learnt that last year when i organised buying the nos rears that they had left ..had to convince them they where for chevs as well !
Old May 8, 2001 | 12:15 AM
RARE-ROC-Z's Avatar
hey i just found out that i had a nine bolt all along, i always thought i had a 10 bolt since the service manual said that the 9 bolts stopped in 1989 but i came to the conclusion. there were no 1990s made in 1990 so i guess it was made in 1989 when the 9bolts were in production still!
good deal i guess, now i want to find some 3.70 gears and have them installed!
but i think i will wait on the rearend since i plan on a moser 12bolt when i get back from the military! oh well it will all work out!!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Custom Interior
mods: AFPR, B&M megashifter-HD4ft cable, Underdrive Pulleys, Ported plenum, K&N's, Magnaflow muffler, Aluminum Driveshaft, Gutted Air Boxes w/ Ram Air, and more!!
soon to have new PAINT, and suspension work
DAILY DRIVER: 1991 S10 2.5L/5SPD -
Old May 8, 2001 | 12:35 PM
ONEFINE8T9's Avatar
my 85 trans am has the 9 bolt posi/disk rear. if u havent found proof ill scan my RPO sticker for you, let me know.....
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old May 8, 2001 | 03:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by RARE-ROC-Z:
</font>
Now that is interesting, because all the other 1990 cars I know of have 10-bolts!
Old May 8, 2001 | 09:01 PM
RARE-ROC-Z's Avatar
i know kevin i thought the same thing. and when i first got the car i looked to see and i thought i counted 10 bolts, but i must be retarded because i have the plastic fill cap on the back and the two tags. i am for sure my car is a 1990 but it was made in AUGUST OF 1989 so i dont know what is up.
i was just about to order a 10 bolt aluminum cover, glad i didnt, but i would have used it on my S10, haha. but now i am just gonna wait and by that MOSER 12 BOLT. i cant wait. its 2300.00 but the govt will pay that! ARMY!!
and what can i do to strengthen that 9bolt? anything. and what gears are offered. i know a bunch about 10 bolts but i always skipped the 9 bolt guru. so i am lost now! any help? thanks!
and hey i know TRAXION has a 10 bolt, and his car looks the same as mine. i was wondering if my rear was changed but the original shocks and stuff are still there. and all the stuff looks stock, and susposedly the car was stock when i bought it. oh well its still kinda fast.
and i heard the 9bolts were stronger than the 10 bolts!
Jarrad
TH-700R4
Old May 9, 2001 | 07:17 AM
LFN AT U's Avatar
The 9-bolt is quite a bit stronger than the 10-bolt. I've heard of people running in the nines with them with no problems at all. I'm pushing 500+ horses through one of mine.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
