3rd Gen Chastain Louvers Help needed
Old Feb 7, 2006 | 10:52 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
I got a set of those louvers but all the hardware is missing.
So i have the 2 outer pieces and the big middle section.
Who has a copy of the instructions or the hardware pieces ?
Please help me and offer me anything u have
thanxs
Alex
Old Feb 7, 2006 | 05:55 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
We need to know what louvers you have. There were many types. The 3 most popular kind were Hammond, Cragar and factory. These were all te 1 piece look.
Old Feb 7, 2006 | 06:03 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Well just reading his post and using a little common sence it wouldn't be a one peice set, it must be a 3 peice set .
It would greatly help if we could know if they are factory or aftermarket!!
Kyle
Old Feb 8, 2006 | 01:56 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
The company that made my one is called Chastain and it´s a 3 piece louver. Those are the ones that where also used on the mse trans am´s in 82.
They are complette out of metal. Which ones are the factory ones ?
Old Feb 10, 2006 | 05:10 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
Isn´t there anyone here who has that kind of louvers ?
IF u check this link (the red MSE with the louvers)
Red Trans Am with Louvers
You will see the kind of louvers that i have.
thanxs 4 your help
Old Feb 11, 2006 | 11:13 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Sorry, I can't help with your problem. Mainly here to say that I know the louvers. Chastain "Shadow" was 3 pieces, like you said, and was the top aftermarket louver in both style and quality back in the '80s. I had a set on my '83 Z28... back in the '80s. The louvers, instructions... and the car, have been long gone since... the '80s.
Old Feb 12, 2006 | 01:47 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
But maybe you remember how the middle section was connected to the outer pieces.
Where those only connected on the bottom ? There is a thin metal bar on each of the outer pieces but i can´t find anything where those should be attached to.
I know that the outer pieces are attached with 5 metal clippings to the window.
But where is that bar going and how was your middle section attached ? Only with the 2 bigger clippings on the top and then cliped into the outer pieces or was there something else ?
Someone told me that the purpose of that louver was that u could still lift the middle section without removing the louver.
Is that true ?
Old Feb 12, 2006 | 06:38 AM
LAFireboyd's Avatar
Yes, it was designed so you could lift the middle section up to clean the glass without having to remove the louver. So it was somehow "hinged" at the top. And (I think) the middle section only attached at two places at the bottom where it overlapped the side pieces. And those side pieces attached, not only with clips to the glass' frame, but also with a flat metal piece(about 1" wide) at the bottom that slid down between the glass and the rear deck.
I'm thinking that's all there was to it.
Old Feb 12, 2006 | 09:09 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
thanxs 4 your help. One last question.
What´s about those 2 bars that are on the outer pieces on top.
They are about 8 inches long but i can´t see anywhere where those should get attached. Can u remember where they belong ?
Old Feb 12, 2006 | 11:23 AM
LAFireboyd's Avatar
I was hoping I could tell by the pix you linked, but I can't.
Just guessing, those bars seem like they'd have to be related to the lifting(hinging, pivoting) of the center section. So could they slide through holes in the sides of the center section, providing its pivot points, securing the center section to the side sections at the top?
Old Feb 12, 2006 | 07:21 PM
scottmoyer's Avatar
Kyle
Your banging your head to my post regarding the 1 piece or 3 piece? I know they are the 3 piece that he has. I was merely stating that the most popular were the 1 piece by those manufacturers. I guess I can now towards you for asking him if they are factory since everybody knows the factory sets are the 1 piece look!
Old Oct 24, 2013 | 05:18 AM
Classicroute66's Avatar
Car: 92 Camaro
Engine: 3.1
Re: 3rd Gen Chastain Louvers Help needed
I know this is an old post, but if you still need help, let me know. I just picked up a set in mint condition and could post some pics of the c
lips.
Old Oct 24, 2013 | 09:10 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
lips.
yes, please do post pics of your louvers.i bought mine without the mounting hardware .but i fabbed what i needed.it will be interesting to see how the company that made them ,mounted them
Old Oct 24, 2013 | 10:58 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
That would be great!!
Old Oct 24, 2013 | 05:00 PM
Car: 92 Camaro
Engine: 3.1
The only thing I didn't have were the brackets that went on the window that the hinges bolt to.....I just made some at work. Had the other clips though.
Attached Thumbnails 3rd Gen Chastain Louvers Help needed-l1.jpg   3rd Gen Chastain Louvers Help needed-l2.jpg   3rd Gen Chastain Louvers Help needed-l3.jpg
Old Oct 24, 2013 | 05:14 PM
Car: '87 Camaro
Thanks for posting the pics!
I will be puting our louvers on come spring.
Old Aug 12, 2014 | 04:18 PM
emckee03's Avatar
Car: 1988 chevrolet camaro
Engine: 305 small block
Transmission: 700 r4
Axle/Gears: borg and warner 9 bolt 3.27 posi
can somebody post pictures of what holds the bottom of the louvers down on the factory 1 piece. I have the hinges for the top but not the ones on the bottom any info would be a big help
Old Sep 5, 2014 | 10:13 PM
emckee03's Avatar
sorry guys im new to this site and didnt know that you guys were replying and just seen all of your posts. anyway they are the factory 1 piece. they are made out of aluminum. im just trying to figure out where i can buy the hold downs for the bottom or would it just be easier for me to make them, because ive heard of people doing that before..
IROCZ1989
Jan 24, 2016 03:55 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
