Can GM get my RPO's for me?
When i bought my car, i found out that the previous owner had replaced the console cover because it was cracked and neglected to switch the RPO sheet...great. So i was wondering if my local Chevy dealer could give me another RPO sheet based on my VIN. If not, could there be another copy of the sheet hidden somewhere in the car? Or another source on the internet to find it? Thanks guys.
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 180* TSAT, 3.42s, 800 Watt System, !EGR
86 Camaro
LG4, Tuned Q-Jet
Any dealer can run your VIN and print you out a list of RPO's, though once the sticker is gone, it's gone.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Jason E says GM can only do it for '90 and later models!
1985 Iroc-Z, 5.0 liter H.O. Hard Top!! Upgrades: Edelbrock Performer Rpm Intake, Holley 650cfm Zinc-plated carb, Flowmaster exhaust,Accel 8.5 spiral core wires, B&M Megashifter, 700-R4 w/shift kit, 3.23 posi.
Soon to have:
A paint job!!! White w/ black sripes, Headers and y-pipe and 3" I-pipe, World-Class 5-speed swap, Disc Brake Rearend from WS6 TransAm, Lots More!!!!! If the funds are available!!
Soon to have:
I stand corrected
so am i just out of luck then? or is there another place somewhere in the car i might find a build sheet?
86 Camaro
LG4, Tuned Q-Jet
86 Camaro
LG4, Tuned Q-Jet
BUILD SHEET IS MOST LIKELY ABOVE FUEL CELL-GOOD LUCK FINDING THAT THING IN ONE PIECE! IF NOT THERE, TRY UNDER YOUR CARPET IN THE REAR AREA OF VEHICLE. UNFORTUNATELY, I HAVE DEALT WITH THE SAME RUNAROUND "WE DON'T HAVE INFO ON ANYTHING MORE THAN 10 YEARS OLD" CRAP THAT YOU ARE EXPERIENCING. THEY ACTUALLY HAVE PLENTY OF INFO-IT WOULD BE WORK TO ACTUALLY GO THRU ARCHIVES AND OLD FILES. NOW IF YOU CALLED UP WANTING INFO ON A 68 CAMARO - THEY WOULD JUMP TO FIND ANYTHING YOU NEEDED (I'VE TRIED THIS). I SUPPOSE US THIRD GENERATION PEOPLE HAVE TO WAIT A FEW MORE YEARS-THAT WAY THEY CAN CHARGE US OUT OUR REARS TO RESTORE OUR VEHICLES-LIKE THEY DO TO THE 1ST AND 2ND GEN. PEOPLE.
Car: 86 T/A
Engine: 5.0 TPI
My GM dealer would have helped me if he could, but he couldn't access the codes on my 86 due to being an older car.
It is possible to basically reconstruct your own codes pretty accurately. There are 3 or 4 codes you will never find. There are many that are base level codes easy to figure out from your car. Then the Pontiac Historical Society can supply you the original invoice for your car for $35.00 that will show the options your car was ordered with those RPO codes. Then find a label like this one:
....and start constructing your own.
[This message has been edited by MikeInAZ (edited July 22, 2001).]
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
