HELP!!!! cant jack up my car... !!!
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
tried to jack up my car to put jack stands underneath the front but cant find a good spot... both my manuals say to use the rocker notches along the side closest to the wheel... tried it and it bent and popped! looked under and its the same on both sides!!!! dammit... its an 85 iroc so i guess over 21 years its been up a lot... so anyway, i need a location where i can jack the car up, maybe up front somewhere on the frame... need help quick!!! thanks all...
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Jack it up under the crossmember (the thing the engine sits on) and put the jackstands on the frame rails just behind the front wheels and in towards the center of the car a bit. They're huge metal rails, can't miss them.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
another thing... can anyone post pics of their cars jacked up or on stands??? thanks again....
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I jack mine up under the k-member in front and the jack stands under the control arms. Under the axle housing in rear or rear control arm bracket.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
how high should the vehicle be? should i do one side at a time or jack up in the middle of the car upfront??? one more thing, do i have to worry about any frame flexing since i have t tops.
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
Dont worry about it flexing, and u can jack it up any way you feel comfortable just chalk the wheels when ya do it, and as far as how high its all up to you and what you are doing to it
Car: '72 Chevy Nova
Transmission: TH350
I suggest jacking it up by the middle in front on the crossmember like I said above. You can jack up just one side if you really want too, wouldn't hurt it.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Lifted the car from under the rear end, and since the car was at a bit of an angle, we put two jack stands under the drivers side subframe connector and one under the passenger side. I definitly wouldn't do this again (wasn't my house), but we made sure the car was very solid.
for the front, I jack the car under the k member. Incase you aren't familiar with it..
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
If you don't need to remove the wheels, then you might want to use ramps. Sometimes, I drive the car up on ramps, but if you do that and have ground effects in front, you have to be careful and maybe even use a 2x4 in front of the ramp to make sure the gfx don't get wrecked. Or, you can jack the car up from the engine crossmember or the rear differential housing and then put the ramps under the wheels and lower the car. I have 6 ton jack stands that I like, but sometimes I feel like good quality ramps are safer.
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
I have resorted to driving my car on top of those cement blocks in parking spaces. More than enough room to crawl under and get the oil changed
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
i ussually end up having to jack mine up in the spring pocket area on the front Arms since that is the only place my floor jack will fit ( the k-member actually sits lower than the jack lol) for the rear i jack it up using the cnter like everyone else. For the jack stands same thing.. i use the frame rails. or the rear axel (where the Pads are) on my 83.... the 84's are both up far enough that i can use the k-member. but still put the jack stands in place ( although on the z28 i have to use the lower control arm mounts due to the sway bar being in the way otherwise)
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
finally got the car up, PITA to me! car is so low, jack wouldnt fit anywhere... anyway, should my front wheels be able to turn when their off the ground??? or should they be locked...??? cant get the front wheels off...
Engine: LT1; None
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
dont understand why the front wheels arent locked like other cars and my durango??? i do have it in park with e-brake on..... why have brakes if they dont work with the car in the air or on the grnd???
Park locks the drive wheels, to whatever extent the differential allows. If a wheel isn't a drive wheel, then Park won't have any connection to it.
Parking brakes only exist on the rear wheels. Even on FWD or 4WD vehicles.
Up until only a very few years ago, NO cars locked their front wheels when in Park.
roysatikas
Sep 22, 2015 08:15 PM
