purpleZ-28
close
- Join DateAug 2005
- LocationSpringfield, Oregon
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car85 Z28, 88 GTA, 68 Cutlass S
- Engine305TPI X2 ;), Chevy 250
- TransmissionT5, 700R4, powerslide >:(
- Axle/Gearsposi, and posi w/discs :D.
- Liked:0 Times in 0 Posts
so what is the difference? theyre both listed as 5.7 V-8's? and was L98 ever posted on an RPO sheet? I did a search but didnt find many answers.
the only 5.7 ever put in these cars was the L98. I have never heard of a B2L???
L98 is the engine code.
B2L is the engine "package" code.
The original L98 in the 1985 Corvettes had cast-iron heads.
jms
jms
For some odd reason Chevrolet used this code for the 5.7/350 in the Z28/IROC(is it the same for the Formula-T/A-GTA?).It's basically the L98 used in the Corvette but with iron heads instead of aluminum ones.It breaks with Chevrolet's long tradition of the "L" designator codes for engines.Although they have the aggravating tendency of reusing the codes.The oil cooler may have been part of the B2L package.
iirc B2L was the package that contained the engine and the upgrades that were necessary with it on an IROC.. L98 is the actual RPO code for the engine.
purpleZ-28
close
- Join DateAug 2005
so they are bassicly one and the same? did L98 come on your RPO sheet? ive heard that the 350 3rd gens didnt have L98 on the RPO sheet.
RPO-B2L was the order number for the L98 350 TPI on the IROC Camaro.
My windowsticker shows B2L, but the buildsheet says L98. I'm not positive that B2L is the package because some of the mandated items for the L98 are itemized on the windowsticker with a price. I've believed it to be a package, but recently have been questioning this.
My 1990 GTA has both B2L and L98 listed on the service parts ID sticker..
I think it's just a bit of redundancy in RPO codes
As another example of this.. I have code MD8 for the 4 speed automatic transmission as well as MX0 which is also the code for the 4 speed auto transmission.
My 91 SPID lists both B2L and L98.
Talk about redundant, my SPID has three emission RPO's, one for FED emissions, one for CAL emissions, and one for EXEMPTED emissions????
My line sheet mentions the trans as MD8. I believe MXO is for the automatic, and MD8 is the type of auto it has.
I don't think any thirdgen that came with the L98, doesn't also have the RP0 B2L. B2L is the order #, L98 is the engine.
purpleZ-28
close
- Join DateAug 2005
so what im hearing is that the L98 was the motor, and B2L is the option number??? wow. good job GM
i might know alittle more if either of my cars actually had its RPO sheet
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
That's exactly what it is.L98 was the motor, and B2L is the option number
B2L included for example the oil cooler. Something that's not strictly part of the motor, but was required in order to install it.
I fail to see what's so stupid about that.
You got a motor, it has a part #; you want to put it in a car, in order to do that they put the motor into a kit that contains the motor AND all of the installation goodies; then you buy the whole package and they install it. Not rocket science, just an ordinary everyday manufacturing type of procedure used universally throughout industry.
It's in your SPIDs twice because those are Service Part IDs; some parts are listed by the L (engine) number, and some parts by the B (option package) number.
Yep, couldn't have said it any better myself. This man is 100% correct.Originally Posted by sofakingdom
That's exactly what it is.B2L included for example the oil cooler. Something that's not strictly part of the motor, but was required in order to install it.
purpleZ-28
close
- Join DateAug 2005
that makes alot of sence really. that bassicly means B2L is just the accessories on the motor that the 5.7 needed to perform at its best.
thank you!
thank you!
