Automatic Trans
Old Jul 14, 2006 | 05:17 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
Automatic Trans
I have a 92 Z with the automatic. I always thought that it was a 700r4 but did I read that 92's came with the 4l60? Any help would be great since I keep destroying the 700's
Old Jul 14, 2006 | 05:30 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
same thing different name...
If your tranny is in good shape...simply a shift kit and a corvette servo should be enough to keep her going. I'd recommend the transgo kit, it also comes with a servo. TV adjustment is crucial.
Also depends on how many ponies you're pushing, seeing your sig says you have a 383.
My buddies and I dropped my 350HO in my 87 about 2 years ago. It was originally a 305/700r4 deal.
I would say I'm pushing a lil over 300HP, and my tranny is just now on its last leg....I think the 3/4 clutchpack is toast.
...All in all, a 4l60 is a 700, and a properly running 89+ tranny w/ mild upgrades and a correct TV should be enough to keep you on the road, depending on how wild that 383 of yours is...
Old Jul 14, 2006 | 07:02 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
as far as i kno the 4L60 and the 700R4 are the same trannies. the main difference that im aware of is that the 4L60 is an electronicly controlled tranny, controlled by a PCM, where as a 700 is not. good tranny for mild power tho. hope that helps.
matt
Old Jul 14, 2006 | 08:10 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
auto trans
I knew that the 4l60 was electronic and the 700 wasn't and I thought that the 4l60 started in f-bodies in 93. I would kinda think that if you interchange them that the way they shift would be impaired. I was just curious what was supposed to be in the car
Old Jul 14, 2006 | 11:42 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
The 4L60 is the same as the 700 except the 4L60 used a electronic speedo sender instead of a cable driven one. They both used TV cables. The 4L60E started in the 4th gens and was fully electronic with no tv cable used.
Old Jul 14, 2006 | 11:58 PM
the 4L60 started in 94 cause the 93 cars were still ecm controlled. atleast i think thats right
Old Jul 15, 2006 | 11:37 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
A 4L60 and a 700R4 are the same tranny. A 4L60E is an electronically controlled version of the same tranny and was introduced around '93 (back from my S-series days, I'd imagine it was the same for the f-bodies).
Old Jul 17, 2006 | 11:04 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Just as a little exta info. The 700r4's and the 4l60e's use different filters in the pan. Found that one out myself. As far back at '88 some of the F-bodies had electrically driven speedometers. I've got an 88 Formula and a 91 RS with wires instead of cables. Oh, the RS is a 5 speed but the point if electrical speed sensors were used prior to OBD2 cars
Old Jul 26, 2006 | 06:16 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
4L60= non ECM cntrolled 700r4
4L60E= ECm control 700r4
E is the ECM control,
its real simple
4l60E came around in different years for different vehicles, as early as 92 and maybe some 91's
it was a phase in over a few years, hit and miss
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Jlanz55
Aug 17, 2015 07:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
