Resto Help
Old Oct 10, 2006 | 08:58 AM
Freak_Z's Avatar
Car: 1983 Berlinetta
Engine: Chevy 305
Transmission: TH-200
Axle/Gears: 10 Bolt - 3.73
Resto Help
I am currently restoring a 1983 Berlinetta, and I am wondering if a 350 would be a good engine ot put in it.
All comments will be helpful.
Thanlk You
Old Oct 10, 2006 | 09:05 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
If you are starting with a 305 then a 350 upgrade is great.
Relatively simple to do, especially for that year.
Old Oct 10, 2006 | 05:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanlk You
A resto means all original
Berlinetta (V6) Engine Transmission
2.8 Liter V6
173 cid. (LC1) 5-spd manual (S)
(O)
Berlinetta (V8) Engine Transmission
5.0 Liter V8
305 cid. (LG4) 5-spd manual (S)
(O)
Old Oct 11, 2006 | 07:23 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
2.8 Liter V6
(O)
5.0 Liter V8
(O)
A resto doesn't have to be all original. Unless you are going to shows and trying to get trophys for an all original car. TONS of people do modern upgrades to their restos, I say go for it!
Old Oct 11, 2006 | 07:34 AM
Freak_Z's Avatar
Engine: Chevy 305
engine and interior help
I am planning on eventually taking the car to shows, but not in an all original category.
I have another couple of questions.....What is the best possible way to get the most power out of a 350 with using as many stock parts as possible?
My other question is Should I use original 83 style seats, or get newer or aftermarket seats?
Old Oct 11, 2006 | 03:21 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Upgrading to a 350 is a good choice and it still gives the appearance of being original(as long as it's a 350 with the perimeter bolt valve covers).An upgrade you may want to consider is the transmission.
Changing out the TH200 3 speed auto to a 700R4 would be very beneficial(deeper first gear and an overdrive for highway cruising).With the 3.73 rear gear having overdrive would be welcome.And again the original look is maintained because the 700 was optional in '83.
Speaking of the rear end you can upgrade to rear disc and some type of limited slip if not already equipped that way.Upgrading the suspension is very easy using factory or aftermarket parts.
Being you have a Berlinetta you already have the deluxe interior.You could change out the seats to later 3rd Gen T/A,or GTA or go to a 4th Gen seat.A lot of people on here have done complete swap to 4th Gen interior.I have a '83 also,Z28,but she has the custom cloth interior in doeskin tan.I'm very happy with the interior(especially since I lucked out on a mint set of seats from another member).The only change I've made to the interior is a swap to a 145 mph speedometer from the dual needle setup.
Old Oct 12, 2006 | 07:21 AM
Freak_Z's Avatar
Engine: Chevy 305
For my resto I was planning on installing a B&M Megashifter in my berlinetta. would that be a problem if I installed the TH700R4 transmission?
plm99
Southern California Area
Nov 16, 2015 05:21 PM
mx127
Aug 10, 2015 08:13 AM
RPM WOT L 98
Mar 22, 2003 12:18 PM
davecamaro
Jan 4, 2003 10:14 PM
RSRagtop
Feb 18, 2002 09:10 AM
