Iroc center caps
Old Apr 5, 2007 | 06:32 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Iroc center caps
Which of these two center caps came on the 85 irocs with gold wheels originally? Mine has the silver ones on now but i thought they came on the 88-89 wheels only.Tell me if im right or wrong. Just trying to figure out for originallity.
Old Apr 5, 2007 | 09:01 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Iroc center caps
The 85-87 cars had the black inserts, while the 88-90 cars had the silver. If you need the black ones with gold type, let me know. I have a set that are brand new from GM that I want to get rid of.
Old Apr 5, 2007 | 09:33 PM
spitstickler's Avatar
Car: 86 IROC (Red on Red)
Engine: 305 tpi
I have an 86 IROC that came new with silver on silver center caps. But, my wheels are silver, so I'm sure that makes a differrence too.
Old Apr 5, 2007 | 10:35 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
My 85 had the silver inserts stock (I believe), I changed them to black with red print.
Old Apr 5, 2007 | 11:31 PM
scottmoyer's Avatar
ALL 85-87 IROC-Zs had the black inserts. The silver was started in 88. If any car has silver prior to 88, the previous owner swapped them out.
Old Apr 6, 2007 | 12:05 AM
Engine: 305 tpi
All I know is that these were the center caps that were on my car when I bought it in Jan of 87. I was the second owner and I can't say what happened to the car before I had it, but the car only had 5k miles on when I bought it and I'm pretty sure the only thing the guy the guy I bought it from had done to the car was fill it up with gas and change the oil a couple of times.
I certainly don't claim to be an expert here. Just trying to help the guy out.
Old Apr 6, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's what my 85 has.
JamesC
Old Apr 6, 2007 | 06:23 AM
babsirocz's Avatar
my 85 also has the BLACK inserts.
Old Apr 6, 2007 | 01:50 PM
cdartz's Avatar
I can help settle the black vs. silver on the 85-87 cars. There were all black, but if the black plastic fell off, or was intentionally peeled off, then you are left with silver underneath. Look at spitstickler's picture. That is exactly what they look like after the plastic has fallen off. Notice how it's clearly different than the brand new one 85Iroc-Z has pictured in his post.
Old Apr 6, 2007 | 02:09 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You are absolutely right, I remember reading that over a year ago.
Old Apr 6, 2007 | 04:17 PM
87_Injected's Avatar
Car: 2010 2LT RS
My 89 IROC vert had the black center caps on it. I guess it was swapped before I purchased it. However I think the black looks better than the silver.
Old Apr 14, 2007 | 11:51 PM
iroc240_3's Avatar
Now i'm confused. I have the 89 iroc 16" whell, which were optional because the 15 was standard. I thought there were 2 different size caps made in silver, 1 for 15 and the other for 16.
I need a siver set for the 16" Where can I find these, Does anyone have a nice set they would sell?
Old Apr 20, 2007 | 12:10 AM
Drew's Avatar
Try a GM dealership parts counter. Get ready to spend a bit, they aren't cheap.
Old Apr 20, 2007 | 10:06 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
My 85' IROC had Black with gold decals & gold on black center caps.
Old Apr 20, 2007 | 10:59 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I got a set on Ebay, repros, about $50. Look as original except the back side has no GM markings. I think, pretty sure, they fit both size wheels.
Old Apr 21, 2007 | 08:23 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The standard 15" 5 spoke wheels were the same as the '82-'86 Z28(optional some years standard others '88 up RS).The only difference being,when used on the Z28/IROC,the caps are black.The wheel caps between the 15" and 16" are completly different.
Old Apr 21, 2007 | 09:17 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I think we're getting confused here.
Early years IROC wheels, black snap in center:
The general Z28 and 15" wheel used on several models with cup shaped center:
The 16" late IROC wheel with snap in silver center:
And the similiar wheel in 15 inch with snap in silver center:
Old Apr 25, 2007 | 11:28 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I bought just one (a silver one) from a dealership about 7 years ago for $60.00CDN!!!! Crazy price but I only noticed it missing a day before a car show and had to have it. Better deals are to be found in the aftermarket.
Old Apr 26, 2007 | 07:36 PM
Drew's Avatar
Even with the conversion rate, it sounds like you got screwed. They shouldn't be that expensive unless the dealership is tacking on a rediculous mark up.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
