Original Trim Colour
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I want to paint the hood louvers on my 89 IROC. What is the colour I can get and where can I get it from.
Will a semi-gloss black from Home Depot or Parts Source be enough or do I need to go to the dealership.
Need help................thanks
Car: 1992 RS
Engine: 3.1
Re: Original Trim Colour
I would think any semi-gloss, matte black, or even flat black would do the trick. I'd just make sure its heat resistant and won't fade in the sun. I'll let someone else chime in who actually repainted them.
I'm pretty sure that OEM they're molded in black plastic. I'd probably use a decent quality black spray paint in whatever type finish you think will look right. When they aren't treated they're a semi-gloss, when you wax them they're shiny. Take your pick.
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Go to the parts store and get a spray can of duplicolor trim paint. http://www.duplicolor.com/products/trim.html. It's the correct black for trim. Adam :-)
Car: 89 IROC
Adam,
GREAT.....thanks
GREAT.....thanks
The link states that the paint is flat black. The trim on the car is supposed to match the headlight pockets which should be a semi gloss finish. I'd check on the match of this paint before buying it.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
SEM Trim black, hands down perfect
John
John
Car: 89 IROC
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
