vin decode?
Old Jun 10, 2007 | 12:14 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
vin decode?
i want to know where and when my car was "born". i have a 1989 camaro RS.
Old Jun 10, 2007 | 12:26 AM
AmorgetRS's Avatar
Re: vin decode?
Van Nuys, CA, and your vin won't give a date.
Old Jun 10, 2007 | 09:01 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Re: vin decode?
ok, sounds reasonable. there was a guy at the ontario camaro nationals he knew the exact date his car was built, however it was a 4th gen. how do i get the same information regarding my third gen? also how do i tell if my 305 is in fact an original engine for my car. i know my car has 156K on it, but i always assumed it was on its second engine. it still has a 305, but the block has yellow witting on the block like a junk yard would do. how can i tell?
Old Jun 10, 2007 | 02:50 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: vin decode?
Look on the right(passenger)side of the deck just in front of the head.If the block hasn't been decked(or the numbers/letters ground off)you'll find a series of numbers and letters that will give the engine code,build plant/date and the sequential part of the VIN.If it's the original motor to your car those numbers should match.
On the '82-'83(possibly '84)the radiator trim tag had the build date in month and week.I know they used the trim tag in later 3rd gen but I'm not sure if this info was still on them.
As Amorget stated Van Nuys was the given for build plant(VIN eleventh digit L)for your '89 since '87 was the last year for Norwood F-bodies.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Elephantismo
Feb 13, 2019 12:51 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
AussieZ28
Sep 30, 2015 03:36 PM
F-body-fan
Sep 24, 2015 08:29 AM
