Found this under my carpet
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Found this under my carpet
I've found those before, but I don't know what they are either. They are some sort of build sheet but with less info, I guess. What seems interesting about yours is there's a code for an antenna, but it says no speakers.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Yep, that's a build sheet. I still haven't found mine yet, but I haven't pulled the carpet out yet either. They're pretty cool to have if you plan on keeping the car all original and want to get top dollar for it 20+ years from now.
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
NO THATS NOT THE BUILD SHEET.
The build sheet looks like this
It's some kind of "other" production line control document besides what we normally call the "build sheet". Maybe you could call it a "work order", "pick list", "packing list", or something like that.
I'd suspect that the "no spkrs" refers to optional speakers; that is, the radio code (missing, so it must have had whatever the standard base-model one was) put some kind of speakers in the car, but only the basic ones that came with that radio pkg.
Car: 86 Sports Coupe
Engine: 2.8L V6
RPO codes say radio delete, no speakers but your right, it has an antenna.
This is a base 86 sports coupe v6 auto.
So it is not a build sheet, but is it a line assembly control document. Strangely I found something very similar but corroded beyond recognition underneath carpeting behind the driver's seat rear bolts. It appears to have been glued to the sheet metal.
Engine: that I like
Is it still a radio delete car, or did someone put in a radio? I don't think I've ever seen one before.
Engine: 2.8L V6
If I understand correctly, in the 80s, aftermarket radios had left manufacture radios far behind. Many people back then who wanted "sports cars" usually ordered these without the radio or speakers (factory speakers were abysmal). Dealers many times would order a car without a radio and then put in an aftermarket radio. It wasn't uncommon. My mother bought a 1986 Chevy Silverado new and it had a crappy fm/am delco radio with the push button manual presets. Many others at this particular dealership (Bolin Ford/Chevy in Bristow, OK it's still there), didn't have factory radios or had aftermarket jobs.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
The "NO SPKR" (singular, not spkrs), may have been reference to a standard speaker package for the radio. Nothing upgraded.
Hard to say for sure. Just ideas.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I found three different sheets like that during my tear down. I found one under the seat, one under the carpet and one in the rear render well. I never found a build sheet though
Engine: 2.8L V6
Here are my RPO with the description from camarosource.ca rpo decoder
RPO Description
A01 WINDOW TINTED ALL, SHADED WINDSHIELD
AR9 SEAT FRT BKT, DELUXE
B84 MOLDING B/S EXTERIOR
C60 HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
D35 MIRROR O/S LH, REMOTE CONTROL, RH MANUAL CONTROL, COLOR
D80 SPOILER RR END PNL
DX5 STRIPE 3 SIDE
E5Z ADAPTER SPEEDO - DELETE
E7Z SENSOR VEH SPD - DELETE
E9Z KEY SP EEDO - DELETE
GA3 FLEET INCENTIVE ALYESKA PIPELINE COMPANY (TRK CKGMLST)
GA4 FLEET INCENTIVE PERFORMANCE CONTRACTING GROUP (H/K/U/W-TRK CKGST)
GU6 AXLE REAR 3.42 RATIO
J50 BRAKE SYSTEM PWR
K61 GENERATOR 105 AMP, DUAL INTERNAL FAN, ENHANCED IDLE OUTPUT
LB8 ENGINE GAS, 6 CYL, 2.5L, SFI, V6, CHINA
MX0 MERCHANDISED TRANS AUTO PROVISIONS, O/D
N33 STEERING COLUMN TILT TYPE NA5 EMISSION SYSTEM FEDERAL, TIER 0
P06 TRIM DISCS WHEEL
P20 HUBCAPS WHEEL, STYLED
PC5 WHEEL 15 X 7, STEEL, STYLED
UL5 RADIO - DELETE
V73 VEHICLE STATEMENT USA/CANADA
VAN PLANT CODE VAN NUYS, CA, USA
VK3 LICENSE PLATE FRONT FRT MOUNTING PKG
199 PRIMARY COLOR EXTERIOR, SPECIAL (GM BRAZIL USAGE ONLY) (NOTE: WILL BE PURGED IN 2000 MODEL YEAR)
19B TRIM COMBINATION CLOTH, EBONY (B) (00)
19B TRIM COMBINATION CLOTH, EBONY MALIBU (B) (FRONTERA 98)
19I INTERIOR TRIM BLACK (I) (96) 19I INTERIOR TRIM EBONY (I) (00)
19I INTERIOR TRIM EBONY MALIBU (I) (FRONTERA 98 )
19I INTERIOR TRIM EBONY/BLACK (I) 02
1AY ORDER MODIFICATION STOCK
41L SECONDARY COLOR EXTERIOR, BLACK (96)
41L SECONDARY COLOR EXTERIOR, BLUISH BLACK 3, (02), HOLDEN
41L SECONDARY COLOR EXTERIOR, KRYPTON GREEN MICA (99) OPEL
6XR COMPONENT FRT LH COMPUTER SEL SUSP (6XR)
7XR COMPONENT FRT RH COMPUTER SEL SUSP (7XR)
84U PRIMARY COLOR EXTERIOR, OPERA RED TINTCOAT (03)
84U PRIMARY COLOR EXTERIOR, RADIANT RED (02)
84U PRIMARY COLOR EXTERIOR, TIGER ORANGE (02) HOLDENS
84U PRIMARY COLOR EXTERIOR, VEGA GREEN PEARL (BRAZIL) (03)
84U PRIMARY COLOR EXTERIOR, YELLOW (02) (SATURN)
8PH COMPONENT RR LH COMPUTER SEL SUSP (8PH)
96A STRIPE COLOR ACCENT, SILVER (97)
9PH COMPONENT RR RH COMPUTER SEL SUSP (9PH)
YT9 FLEET PROGRAM EXPOSURE INITIATIVE I: C/F/G/H/J/K/M/N/S/U/V/W/Z- TRK CKGMPST
RPO Description
DX5 STRIPE 3 SIDE
UL5 RADIO - DELETE
Engine: that I like
Any pics of your car? It sounds very interesting.
Engine: 2.8L V6
not much to it. Used to be a medium grey, now it is some funky white/purple beast from the 90s. Very basic 86 sports coupe model.
Here are some pics
Here are some pics
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It was definately used for the people on the line while making your car. Like a build sheet it was probably used as a tracer to indicate to the workers what equipment went on the car for a particular section of the production process. It may have been a supplimental Build sheet for particular portions of the build.
John
John
rudolphschenker
Sep 4, 2015 02:41 AM
