Firebird Cluster ----> V6 or V8 ???
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
During a recent visit to a local bone yard I found an 82-83 V6 Firebird. It had the small square reverse lights and a 3-speed automatic. While looking over the car for parts I needed; I found that the cluster in the car didn't appear to be correct.
The car HAD a V6 engine in it and it had a cluster with a 30/60 oil pressure gauge. I know that on every other Camaro or Firebid I've seen the v6 cluster has a 40/80 and the V8 got the 30/60 oil pressure gauge. Here are my questions:
1) Are all 82-84 clusters the same ?? 82-83-84 Camaros each had different gauge designs.
2) Did the V-6 ever get a 30/60 oil pressure gauge ? Specificly speaking about the 82-84 clusters.
3) Do the gauges inside the 82-84 Firebird cluster have the application written on them. I recall that the 86 -> up tachs said V6 or V8 right on them.
4) What are the Yellow and Red lines for the 82-84 Firebird V6 AND V8 Tachometers ??
5) Were all 82-84 Firebird Speedo's 85MPH ?? ( X-cept metric, I have a factory 140KPH )
I realize that after 20 + years someone could have replaced the cluster 10 times over this cars lifespan. I'm pretty sure the oil pressure gauge is a V8 spec. I can't remember what the Yellow/Red lines were on the clusters' tachometer or I would have described them above.
I'm not worried about the 85 style or the 86 and up clusters,.........
Re: Firebird Cluster ----> V6 or V8 ???
Allow me to simplify in the hopes of a response ---->
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I can't remember the last time I saw an early v6 bird AND payed attention to the cluster.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
From what I can tell:
1) Apparently they all used the same Sender unit from 82 -84 14039664
2) The 1982 Gage (Oil & Volt) must have been a single unit was 25025713 and there are no other references gages listed...
Unfortuantely I could not find any more info, my book is from 1992 so some things may have been removed as they are obsolete.
John
John
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
My 82 with V8 LU5 has a 60psi oil pressure gauge. My 83 V8 L69 has an 80psi oil pressure gauge. IIRC the v6 had 60psi oil pressure gauge.
P.S. I know that the same oil pressure gauge was used for the V6 and V8 digital Berlinettas and that the only difference is in the faceplate.
Car: 1983 Trans Am
Engine: L69 5.0L HO
I looked through the pics I have and I could not find an 82 or 83 V6 with a 30/60 oil pressure gauge. I did find some pics of 84 L69 with the 40/80 oil pressure gauge, as well as my 83 L69. The LU5 and LG4’s did have the 30/60 oil pressure gauge.
To answer your questions
1) No, the 82's had white needles, the 83-84's had orange needs. 84 also had a different pattern in the tach for red over rev area.
2) Not that I can tell.
3) Non of the gauges I have taken apart have had any markings on them with application.
4) Red lines are:
82 I4 – 5000 RPM (6000 max reading)
82 V6 – 5000 RPM (6000 max reading)
82 V8 – 5000 RPM (6000 max reading)
83 I4 – 5000 RPM (6000 max reading)
83 V6 – 6000 RPM (8000 max reading)
83 V8 LU5 & LG4 – 5000 RPM (6000 max reading)
83 V8 L69 – 6000 RPM (8000 max reading)
84 I4 – 5000 RPM (6000 max reading)
84 V6 – 6000 RPM (8000 max reading)
84 V8 LG4 – 5000 RPM (6000 max reading)
84 V8 L69 – 6000 RPM (8000 max reading)
5) All 82-84 Speedos were 85mph. it was a federal law at the time.
Thanx to all that responded. As usual; sharing your knowledge has once again helped me to learn more and I really appreciate the time you've all taken to reply to this post !
It might be possible that Originally they did have different gages and for one reason or another a gage was replaced by a "generic" item which was one or the other of the gages...
JOhn
JOhn
