TADailyDriver
close
- Join DateFeb 2008
- LocationLowell, Michigan
- iTrader Positive Feedback100
- iTrader Feedback Score(8)
- Car1988 Trans Am, 2005 Sierra 2500
- EngineVortec 357
- TransmissionBuilt TH700R4 with 26-2800 Stall
- Axle/GearsGM 10 bolt 3.73 Posi
- Liked:0 Times in 0 Posts
I have a 1988 Trans Am and the car is getting all new paint and bodywork next week. But im stumped and cant seem to find the paint code. Can you tell me where its at. Ive checked the door jams and under the hood/hatch panels but i dont see it. The car is a creamish white. Help me.
Anyone know what color white this is?
If the SPID sheet is still in the center console, then there is a 4 digit code on the bottom of the sheet. It would read WAxxxx. That 4 digit code is the on the paint guy would use to get the right mix of paint. Not sure what the color is called, I'll try to look it up for you.
TADailyDriver
close
- Join DateFeb 2008
- EngineVortec 357
Quote:
thanks, ya my spid sheet in the center counsel is missingOriginally Posted by RPM WOT L 98
If the SPID sheet is still in the center console, then there is a 4 digit code on the bottom of the sheet. It would read WAxxxx. That 4 digit code is the on the paint guy would use to get the right mix of paint. Not sure what the color is called, I'll try to look it up for you. Senior Member
I'm sure that soon one of the guys that knows the paint code will chime in here. Or option 2, you can call a dealer parts dept and have them run the VIN for RPOs and they should be able to tell you the paint code.
TADailyDriver
close
- Join DateFeb 2008
- EngineVortec 357
sounds good. ill try the dealer and see if they come up w/ anything
Did you ever find the code? My 1986 Iroc is also the creamish white. I'd like to find that code.
The paint code is 11 and the WA # is 3967 for the correct White used on '88 Firebirds.
