What go's in this hole.....?
Old Apr 21, 2008 | 02:11 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
This is on the right side of the runners. i can't figure out whats soposed to be there.
Old Apr 21, 2008 | 04:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: What go's in this hole.....?
Looks to be where your cold start injector goes.
Old Apr 21, 2008 | 05:00 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
The cold start injector is on the bottom of the runner, plus by the looks of it it is a MAP car which also means no 9th injector. I guess someone with a MAP car could answer this very easily.
Kevin
Old Apr 21, 2008 | 08:43 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
That's a threaded hole for a vacuum fitting...for a MAP sensor. There is also another one that provides vacuum for the flappers in the a/c system and the cruise control.
Old Apr 22, 2008 | 08:12 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Does anyone happen to possibly have a part number
Old Apr 22, 2008 | 10:17 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If I am looking at the picture right thats the RH rear of the plenum. IIRC I want to think there are two holes back there, one hooks to the HVAC & accessories like Cruise Control. system another hooks to the EGR, and another should hook to the Fuel Pressure regulator. Its been a few months since I have looked at them so thats from memory.
John
Old Apr 22, 2008 | 07:16 PM
Drew's Avatar
There are three vacuum fittings on the map cars. As mentioned already, they're identical to MAF cars, except there's a third nipple for the MAP sensor hook up. The other two are for the fuel pressure regulator, and the vacuum line to the HVAC system.
Old Apr 23, 2008 | 08:10 AM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
FWIW, I replaced my intake manifold gasket last year and took a bunch of photos of the top end to use as a reference to make sure everything got back together OK.
Like IROCZ28KevinZ says, it's a simple fitting that a vacuum line attaches to. Here's a shot of my '90 L98.
Old Jul 3, 2008 | 11:59 AM
gulf_coast_228's Avatar
Car: 1992 Firebird Trans Am GTA
This isn't directly related but what is the valve at the end of that vacuum hose called? I'm replacing my vacuum lines soon and I have no idea what it's called to get a new one. Thanks!
Old Jul 3, 2008 | 12:32 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Yes that is a MAP sensor up on top. For your '91 L98 part# is 12569240.
I believe the piece you need is an intake manifold vac fitting (1 port - 1/4-18 THD). Part# is 14082470.
There's plenty of them in the GM warehouse. Order at your local dealer (but make sure this is what you need).
chevman24
Exterior Parts for Sale
Sep 17, 2013 12:20 PM
luvmy64
Jun 9, 2011 05:03 PM
treeohfive
Jun 5, 2004 02:05 PM
