I found this paper under my carpet. Does anybody know what it is?
Thanks in advance
-John
Thanks in advance
-John
Never seen that before. Kind'a funky how the tiny characters are used to form the same larger version of itself.
PS; Under the carpet it which location?
Kind of in the lower recessed area where the rear seats go. Im not even sure its camaro related. I found metallic lip shaped confetti in my car so it could be anything....
That's part of the factory build sheet. It typically showed the options the car was built with. See if you can find the rest of it. On a lot of cars, having the build sheet increases the value.
Thats all that was there.....Thanks for the info though.
Quote:
I've never seen print like that on a buildsheet. Here's an example of one (this is 1982TA's) . . .Originally Posted by sleepsinshed
Just curious how you've determined that it's part of one? Thanks.
Wont increase the dead value unless it is a showroom car, like a Barret- Jackson vehicle.
I agree with Iroctopless. That doesn't look like any of the build sheets that I've seen. Could maybe be something else assembly plant related, but not the build sheet.
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
I think that might be the carpet or under layment plant code.
okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
To possibly answer a question or ask more. What is the Sequence number of your Car. Does it match the one on the tag (or at least what is shown?)?
The NGJ RPO is around the area of Gas Tanks & Emissions equipment, so I suspect that it has to do with something in that arena. Beyond that I did not find anything quickly on that RPO NGJ. I suspect it may have been something to do with the Convertor.
