HELP NEEDED!
Old Jun 17, 2008 | 10:15 AM
lcbailey's Avatar
HELP NEEDED!
I am looking at a 1989 Camaro Iroc-Z Convertible.
The console has been replaced so the RPO codes are for a different car. The Iroc decals are on the front of the door rather than the back. Is there another way to know if this is really an IROC without access to the RPOs?
Thanks for the help!!!
Old Jun 17, 2008 | 10:17 AM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Re: HELP NEEDED!
Get the vin and check on the main page to verify. Andrew
Old Jun 17, 2008 | 10:27 AM
lcbailey's Avatar
Re: HELP NEEDED!
where on the main page, I am having a stupid moment and can not find it
Old Jun 17, 2008 | 10:40 AM
Stephen's Avatar
Car: 87 GTA
Re: HELP NEEDED!
I forget the year specifics, but I believe the IROC decal was front/rear of the door, between different years.
Old Jun 17, 2008 | 10:50 AM
lcbailey's Avatar
Re: HELP NEEDED!
I read that the 89 decal was supposed to be on the rear of the door. However I have seen pics with it in both locations. Are there any other clues to figure out it this is truly an IROC?
Did All irocs have foglight?
what badges where were and what colors?
The vin decode only said it was all models
Old Jun 17, 2008 | 11:21 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
Re: HELP NEEDED!
the tenth digit on the vin will tell you what year it is. my car has a g which means it is an 86.
look at the fifth digit, is it a p ? that would mean z28 sport coupe.
Old Jun 17, 2008 | 11:28 AM
lcbailey's Avatar
Re: HELP NEEDED!
the year is an 89
it is a P
so that means a z-28 or Iroc?
were both an option in 89
Old Jun 17, 2008 | 12:40 PM
AmorgetRS's Avatar
Re: HELP NEEDED!
No, they dropped the Z-28 model in 88.
Old Jun 17, 2008 | 12:43 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
Re: HELP NEEDED!
your car should have a k as the 10th digit. not sure about the z28 or iroc.if
your car should have a k as the 10th digit. not sure about the z28 or iroc.if you want to know for sure, spend 20 bucks and do a carfax. that way you will have all the info you need to tell exactly what you have.
Old Jun 17, 2008 | 01:36 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: HELP NEEDED!
If it has a LB9 "F" Engine in the 8th digit of the Vin then its definately a IROC, as no RS's came with the "F" engine in 1989.
If the car has an "E" Engine then there is no way to really tell, as both the IROC and the RS were available with the LO3 "E" engine...
The 10 Digit should be a "K" as mentioned before.
John
John
Old Jun 17, 2008 | 01:43 PM
Stephen's Avatar
Car: 87 GTA
Re: HELP NEEDED!
Originally Posted by okfoz
... no RS's came with the "F" engine in 1989.
John
Not sure if that is 110% accurate...Did the Police Package RSs, have the "wrong" VIN code letter, or did they get the "F" too?
Although....B4C didn't start until '91, so it's a moot point for '89, just a question.
Old Jun 17, 2008 | 03:33 PM
mesterz2889's Avatar
Re: HELP NEEDED!
make it simple just run the vin it will tell you everything you need to know
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
