were can i get replacement keys??
Car: 92 camaro RS
Engine: 305 5.0L
I NEED TO NO HOW I CAN GET A NEW SET OF KEYS IF THATS POSSABLE. MY BROTHER HAD THE CAR IN HIS GARAGE FOR A FEW MONTHS WHILE I COULD FIND A PLACE TO STORE THE CAR. HE LOST THE KEYS AND I'V BEEN LOOKING FOR THEM FOR ABOUT A MOINTH NOW AND IM READY TO GIVE UP. I THOUGHT ABOUT REPLACING THE IGNITION, BUT I WOULD STILL NEED A KEY FOR THE LOCKS, T-TOPS AND THE HATCH......... WOULD I GO TO A CHEVY DEALER? I HOPE YOU GUYS CAN HELP ME.
Car: 87 GTA
Re: were can i get replacement keys??
I know from experience that if you go to the gm dealership and so proof of ownership they should be able to take the vin and cut you a door and ignition key. All though most of my experience is with newer cars. Age of the car may play a small factor. But it wouldn't hurt to call.
Jason
Jason
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Mine were about $20 per key because of the chip. I think they said there are 14 possible combinations of chips.
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
I just talked to my local locksmith and he has the computer crap to make me one with a chip in it for $50.00. So try giving your locksmiths a call. Supreme Member
Axle/Gears: Posi
Car: 92 camaro RS
Engine: 305 5.0L
ok i called the gm dealer they said they could make me the key if i brought the title in. thank you guys for the help!
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
How can I get my passenger door and drivers door to require the same key? Since the previous owner replaced some locks and not others, I have 1 key for the drivers door, no key for the passenger door, 1 key for the ignition, 1 key for the rear hatch and yet another key for the rear hatch cover thing. That's 4 keys for 5 different things and it would be 5 for 5 but I'm missing a key. How can I make my key chain lighter? Just buy new locks?
</div>
</div>
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
You should be albe to take the lock cylinders into a lock smith and they can code everything for the same key.
I'm just replacing the ignition cylinder and VATS and that's what I did to keep the same ignition key.
Car: 1987 IROC-Z
Transmission: TH350
I'm going to guess somewhere between $100 and $150 to do all four. From what I've seen here locally (Vancouver, Canada area) there is a charge of $40-50 for the first lock and additional ones are half that. Not sure how it works for your area.
eightsixseven
Dec 16, 2024 01:50 PM
