Chevrolet 307 Engine?
Old Aug 7, 2008 | 10:05 PM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Never heard of it and was curious. Found a good ad on a Camaro and saw it had a 307, so are they worth keeping in or should I replace it with a 305 or 350?
http://www.bargainmartclassifieds.co...?adid=31081038
Old Aug 7, 2008 | 10:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Chevrolet 307 Engine?
Its basically a 283 block (larger journals though) with a large journal 327 crankshaft in it and pistons with a reduced compression height. The cam was weak and the heads weaker yet. It does have a better bore/stroke ratio than a 305 does though. Aftermarket parts for the 307 are even rarer than the 305, although you can fit larger diameter valves in a 283/307s bore than a 305s tiny bore.
Old Aug 7, 2008 | 10:17 PM
Car: '86 Trans Am
Engine: 305 H.O.
So would you reccomend that staying in the car or if I buy it throwing a spare 305 in?
Old Aug 7, 2008 | 10:44 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
If you are going to go through the trouble of pulling and replacing the engine, there is no reason to choose a 305 over a 350.
Old Aug 7, 2008 | 11:44 PM
Car: '86 Trans Am
Engine: 305 H.O.
My bro will sell me a 305 for cheap. Only reason a 305 is even considered lol.
Old Aug 8, 2008 | 12:04 AM
Bull's Avatar
Engine: LT1; None
Well, cheap is attractive, I understand that!
Old Aug 8, 2008 | 10:21 AM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Know there a very durable engine. IF its the one they put in 80's Buick sedans, > 250 k miles not impossible
Old Aug 8, 2008 | 11:11 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Didn't Oldsmobile use the 307 too? I'm thinking the early 80's Olds 88 & 98 used them.
Old Aug 8, 2008 | 11:51 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
The olds 307 is a completely different motor entirely. Strong design(SBO), but weak power. If I was given the choice between a 305 or a 307, I would choose the 307 in a heartbeat. the larger bore and smaller stroke make it a better engine (IMO). I have heard that all 307's wear faster though, due to the lack of nickel in the block. Rebuilds can come as early as 70k.
Cheers!!
Old Aug 8, 2008 | 08:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They don't.
Old Aug 8, 2008 | 09:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I woudln't bother replacing a 307 with a 305.. doesn't really make any sense.. if you were going to replace it put something with some ***** in there.. it may in fact be a 305 though.. notice the "iroc" rims..
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
