paint code help needed
Old Aug 29, 2008 | 10:34 PM
Hallsresto.com's Avatar
engine color paint code help needed
Im looking for the correct paint code for a L69 Ho 305 block and heads in 1984..i.e i need the original supplier (PPG DITZLER etc) and original number. I need the color to be correct on this car ....
also need to know what was painted and what wasnt and what was other colors , example is the air cleaner same as block and heads , was aluminum intake painted etc????
any help and lom mile car pics welcomed,,Thanks in advance,,jack
Old Aug 30, 2008 | 01:41 PM
Re: engine color paint code help needed
no one?????? are they black , red , blue , purple, orange (LOL) surely someone has an original car here???
Old Aug 30, 2008 | 02:14 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Re: paint code help needed
My 84 H.O. the engine was low gloss black. It was **** coat thin because it started to show rust 3 months after I bought the car new. As for the PPG paint code I have no Idea.
Old Aug 30, 2008 | 02:52 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Everything was black on mine, air cleaner, heads, block, water pump except the aluminum intake which was raw.
Old Aug 31, 2008 | 09:49 AM
thanks guys that helps alot..i can go tot the PPG book and probably come up with the code.. i just know it shows black, a couple of blues etc for the early 80s i think the blue where for the 2.8 6 but wasnt sure ..Thanks again jack
Old Sep 2, 2008 | 02:09 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Nice to see someone trying to do it the correct way.
I have some decent pics of low mileage engine bays if you are interested.
GM corporate blue was only used on thirdgen F-bodies in 1982.
Old Sep 3, 2008 | 07:48 AM
it would help ..we are completing a rotiserie restioration on a 84 H.O. car and it has to be correct...if you could post here or email me to jackhall@hallsresto.com it would be greatly appreciated..thanks jack
Old Sep 3, 2008 | 08:35 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Email sent. About 8 pics. They are high res. so it may take a while to load.
Hope that helps.
Edit: The email bounced. I'll zip the files and try again this evening...
Old Sep 3, 2008 | 06:30 PM
Kevin84Z28's Avatar
I'd love to see some pictures of it.
Old Sep 3, 2008 | 08:58 PM
thanks for the pics guys,,it helps more than you know....Ill get some pics uploaded and on here asap...Thanks jack
Old Sep 4, 2008 | 08:51 PM
69-er's Avatar
My factory ordered 83 L69 had a black intake and t-stat housing. I had the motor out once several years ago to regasket it, but I can't remember the color of the bellhousing. I took pictures. Maybe I can find them if you need that info too.
Larry
Old Sep 4, 2008 | 10:20 PM
Kevin84Z28's Avatar
Larry
They painted over the aluminum intake? I'm not the origional owner of my 84 L69 but it appears that the intake was never painted, and it doesn't look like it's ever been off the car.
Frozer!!!
Jan 19, 2024 04:55 PM
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
