Is this 84 Z28 correct?
Old Nov 13, 2008 | 01:46 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://cgi.ebay.com/ebaymotors/1984-...QQcmdZViewItem
Is that steering wheel original? And the shift ****? Those both appear to be from a newer 3rd gen. And the radio doesn't look right either. Wondering if the previous owner had a bunch of aftermarket parts installed and took them out before he sold it!
Attached Thumbnails Is this 84 Z28 correct?-05.jpg   Is this 84 Z28 correct?-04.jpg   Is this 84 Z28 correct?-18.jpg
Old Nov 13, 2008 | 02:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is this 84 Z28 correct?
Stereo, shift **** and steering wheel are all correct.
Old Nov 13, 2008 | 02:05 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Those are stock for a Z28
That car is clean.
Old Nov 13, 2008 | 02:27 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, I had the exact same car but had the standard square center steering wheel and plastic ball shift ****. Guess I was the one who wasn't stock!
Old Nov 13, 2008 | 02:41 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Everything looks correct to me. That style radio with the push/pull cassette control button was only used for a year or two.
Old Nov 13, 2008 | 03:00 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
The car is very origional, although I'm not convinced that the leather shift **** was an 84 thing.
Old Nov 13, 2008 | 04:30 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
My '84 HO had a leather shift ****. Around '93 or so, the stiching wore out and the leather peeled off.
Old Nov 13, 2008 | 06:54 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
That car is correct. The Z28 provided a leather wrapped steering wheel and shifter. I see nothing incorrect about this car. I'll take it.
If you had a Z28 with the square horn button, then you either didn't have a Z28 or you didn't have a stock steering wheel.
Attached Thumbnails Is this 84 Z28 correct?-00.jpg   Is this 84 Z28 correct?-10.jpg
Old Nov 13, 2008 | 07:18 PM
Kevin84Z28's Avatar
Mine looks just like an eight ball.
Old Nov 13, 2008 | 07:22 PM
TTA 1387's Avatar
That is what is underneath. Just the regular shift **** without leather. Either yours wore off like mine, or somebody swapped it for a regular ****.
Old Nov 13, 2008 | 07:49 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Mine does too, and there was never leather on it as far as I know. -But I have a '83.
Sweet car anyways! But worth 7K??
EDIT: I also have an original dealer's brochure on the '83 model, I'll double check that....not that it matters anyway, still a nice HO...
Old Nov 13, 2008 | 08:25 PM
TOM-1LE's Avatar
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
It all looks right as rain to me. Nice car. I see a lot of that dealer's ads on eBay...for a new car dealer, he seems to have a lot of mint low-mile older cars for sale. I think he has an '89 Formula 350 with under 10K miles on it also.
To me, a mint original '84 H.O. is definitely worth more than $7K, although I would prefer T-tops on one of those.
Old Nov 14, 2008 | 08:40 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Confuzed1 you won't find info on the HO in the '83 Dealer Brochure as the L69 was a mid-year addition. The brochures were printed ahead of fall release and generally weren't updated. It doesn't even show the color of my '83 in it as it was a late release (code 59 beige). The picture one of the manual shifter in it looks like it's leather covered (vinyl maybe).
Although I can't speak for the manual shift ball the one on my '83 auto shifter is leather covered. And another difference between the '82-'83 Z28 is the steering wheel. At first glance they look the same but the '82-'83 wheel has a groove cut in the lower spoke of the wheel. The '84-'88 (or is the last year '89 before the airbag wheel) just have the grooves in the upper spokes. I'm lucky the leather on mine is decent as finding the correct replacement one is hard.
Old Nov 15, 2008 | 10:50 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
My 84 had the same wheel with two grooves, and leather shift ball and e-brake handle.
That is a very clean car, even having what looks like the original tires.
Old Nov 15, 2008 | 04:08 PM
Kevin84Z28's Avatar
Did anybody besides me check out the other cars that seller is auctioning? He has a super clean 83 Camaro Z28 L69 H/O, a 1988 Pontiac Formula and a 1991Camaro RS Convertible.
Old Nov 17, 2008 | 08:35 PM
69-er's Avatar
My 83 leather cover wore off too, but I thought the stitching ran horizontal. I can't remember for sure. I have two NOS ***** and they both run horizontally. I did save my old cover. I'll have to find it to see how it was originally.
Old Nov 18, 2008 | 06:22 PM
TTA 1387's Avatar
Mine ran vertical, just like pictured. Except mine was straight front to back.
Old Nov 20, 2008 | 05:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Ahhh.....no. I have a 1983 brochure WITH the "new" L69 HO option mentioned and it even has a chart as to what options were available on all the models for '83. The only thing it ended up being wrong about was having an automatic trans as an option. I bought my car off the original owner. I even have the "Rusty Jones" rustproofing certificate from the dealer. But you are correct, it was a mid-year addition. My car's original build date was in august.
Old Nov 20, 2008 | 06:05 PM
69-er's Avatar
I had no idea they printed up a late edition brochure that included the H.O.! I probably got my brochure in 82 or early 83.
I'll have to find one on eBay. I see them all the time. I just need to determine where the changes are in it so I get the right one. Do you have any scans of it so I can see what I need to look for?
Old Nov 21, 2008 | 07:21 AM
coolram62's Avatar
Engine: LU5 305 CFI
Confuzed1 I apologise as ,like 69-er, wasn't aware that a late/mid year brochure was printed. basically the '83 was a general reprint with updates of the '82 brochure. If you would have a chance to post a picture of the cover. And also does it show beige as an exterior color option. Thank you
Old Nov 21, 2008 | 09:34 AM
auto_cran's Avatar
Car: 1989 Pontiac Turbo Trans Am
Engine: Buick 3.8liter Turbo V6
Transmission: 4-speed automatic
I have been over to this dealer to check out this car as well as a few others.
This car as well as all the others are the "real deal" - they are SHARP cars. I hear the owner is a big-time car collector/enthusiast. Besides the showroom, he has a warehouse FULL of cars, which we got to see.
I was drooling for quite some time!
Chris
1989 Pontiac Turbo Trans Am #760 (1940 miles)
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1983 Delorean DMC-12
1986 Pontiac Fiero GT V6/5-speed
1986 Toyota Supra MKII
1985 Kawasaki Eliminator ZL900
Old Nov 22, 2008 | 10:33 PM
69-er's Avatar
Hey Confuzed1, do you know what the printing date is for that brochure?
Old Nov 23, 2008 | 01:59 AM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Wow, that was a nice. . . I'd pay that price for it.
Looks like the only thing that Z28 needs is a new set of tires (looked original as well!) and good vacuuming. . . Hope whoever won it enjoys it.
Old Nov 24, 2008 | 07:35 PM
69-er's Avatar
I found my original shifter ball cover. The stitching is vertical. Weird how the NOS ***** are horizontal, although I've seen it before where NOS parts aren't exactly like the assembly line supplied parts.
Old Nov 25, 2008 | 06:10 AM
scottmoyer's Avatar
some years were vertical and others were horizontal. I don't remember what year they switched to horizontal.
Old Nov 25, 2008 | 06:28 AM
69-er's Avatar
Interesting... I'll have to see when they switched. In the meantime, I might try to recover my old ball. I wonder how hard it would be to stretch some leather around a ball and stitch it tightly? Sounds like it would be a PITA.
I did my steering wheel several years ago and the stitching turned out very nicely. In fact, it's doing better than the original did. It's not all twisting around at the top. I'd like to do it again because the material wasn't wide enough to cover the spokes the first time.
Old Dec 2, 2008 | 05:39 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I know 83's are vertical on the automatics.
https://www.thirdgen.org/forums/atta...st-shifter.jpg
Old Dec 3, 2008 | 10:31 PM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
My 84 Z28 with the original leather steering wheel (grooves on the top spokes only), leather shift **** (vertical stitching), and leather e-brake handle.
morrow
Jan 13, 2024 12:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bryanwood74
Sep 24, 2015 09:50 PM
sunbound
Sep 5, 2015 11:52 AM
Regal105
Aug 23, 2015 03:45 PM
