Light bulbs for CAMARO flashlight?
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Any ideas where I can get them? The one I have says phillips #222. Thanks
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Light bulbs for CAMARO flashlight?
I would go to napa or any auto store with the bulb and just say i need one exactly like this. If the counter man is any good he/she will find a replacement.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You might check somewhere like Fry's, RadioShack, or even Wal-Mart, near the bulbs for normal flashlights. I've seen small AA or AAA powered flashlights that use this bulb, like the ones that go on a keychain. Or, if all else fails:
http://bulbster.com/lightbulbs/222-p...FRJxxwodpzXy8Q
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Wagner Part#222. A search is always a good thing. I purchased mine in a hardware store.
JamesC
JamesC
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Just to let you know, i was at walmart the other day looking for a pair of replacements for the two flashlights i have, and walmart doesn't have the proper one for this light, they had a ornament ball like shaped one, not the correct one. Just letting you know so you don't waste the gas to get over there.
Car: 89 Iroc Convertible
Radio shack part#272-1124.On the package it says #243(222) Flashlight lamp.I believe they were less than 2 dollars for a 2 pack of bulbs
Thanks for the replies. I actually did try at napa and the guy was completely confused. Auto Zone was even worse. I did find them at radio shack. Thanks again
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Car: '87 IROC
Engine: LB9
