No RPO Codes
Old Jul 5, 2009 | 11:01 PM
ZTime's Avatar
No RPO Codes
How can I tell the color of the car without these RPO codes?
Its a 1985 IROC that is black with no iroc door stickers,but I did the research a it's a 85 iroc made in cali. The car is not one of the spicial edition cali cars but there are no stickers on the door, and it has the iroc hood and spoiler.
Old Jul 5, 2009 | 11:03 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Re: No RPO Codes
black- color code 19
Old Jul 5, 2009 | 11:21 PM
ZTime's Avatar
Re: No RPO Codes
Does your 85 have the Iroc sticker on the outside of the doors? Thanks
Old Jul 7, 2009 | 01:58 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: No RPO Codes
Read his post again and you'll find your answer.
Old Jul 7, 2009 | 05:35 PM
Dmans85's Avatar
Car: '85 Z28
Re: No RPO Codes
Chances are someone along the way took the stripes off. Maybe didn't like em, maybe to have car repainted. To find out if car is a cloned IROC, you'd have to do some detective work. Label on door showing 16 in tire size or check spring tag if by some miracle still there. My 85 also has the color code on a metal plate on top of the radiator. You might be able to see if you have a non-IROC original color listed. There was a decal delete option, but it started 3 years later than ours, so no chance there
Old Jul 7, 2009 | 07:06 PM
ZTime's Avatar
Re: No RPO Codes
No it does not have the Iroc sticker on the outside of the door.
Old Jul 7, 2009 | 07:12 PM
ZTime's Avatar
Re: No RPO Codes
My cousin bought it from the orginal owner and all checks out for it to be a IRoc it has the round shift *** the 80mphs speedo the Irock bage in the inside and I checked the vin number on a web site and its a z28 but I dont know if it ever had the sticker on the outside of the door. Thanks
Old Jul 7, 2009 | 07:37 PM
ZTime's Avatar
Re: No RPO Codes
I just found the RPO codes it was on the inside of the center console its a B4Z and I just love this car.
Old Jul 8, 2009 | 05:58 PM
Dmans85's Avatar
Car: '85 Z28
Re: No RPO Codes
Man i can feel your excitement from here. Enjoy. Cool that you still had original console top. Well the IROC decals had to be on it once upon a time, unless your original owner too delivery w/o em, like the 4.3 mile guy did. Hope you checked out that thread already.
Old Jul 8, 2009 | 11:20 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: No RPO Codes
Awesome you found the B4Z RPO. Now does the VIN on the RPO label (or SPID) match the VIN on your car? That would confirm it.
Regarding not having the IROCZ decals, there was a stripe/decal delete opton offered on the IROCZ (RPO DX3). However, that started in '88. That means yours should have had them at one time. The most common reason for them to go missing is when someone has the car repainted and doesn't bother to replace them. Should you ever want to replace them, they are easy to find online. http://www.phoenixgraphix.com/ is a good source.
Old Jul 9, 2009 | 10:34 AM
scottmoyer's Avatar
Re: No RPO Codes
another reason for them to be missing is alot of people removed them thinking the car looked cleaner without them. Not always repaint related.
Old Jul 9, 2009 | 08:34 PM
Axle/Gears: 3.08
Re: No RPO Codes
Or they shouldn't have used that industrial rated pressure washer!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
