Question on 1982 Pace car colors
Old Jul 14, 2009 | 07:04 PM
daveSS1987's Avatar
OK anyone that has info on the 1982 Indy pace car, I have a couple of good color photos of one but cannot determine if the dark blue stripe around the mid section of the car is the same color blue as the recessed area on the hood vents. or is it a darker metallic blue? hard to tell from photos, if anyone has paint codes for the blue stripe? i assume the silver is the same metallic silver used on plain Camaros that year.
any help would be useful, I'm trying to paint a model of this car to look exactly like the original.
Thanks,
Dave
Old Jul 14, 2009 | 07:12 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Question on 1982 Pace car colors
1982 GM code 16 on the silver.
1981 GM Bright Blue Poly on the lower (blue metallic) Should be PPG #3340. The hood had a decal, not paint, that matches the paint color.
Old Jul 15, 2009 | 06:26 PM
daveSS1987's Avatar
Thanks Scott! so the blue sticker is a perfect match to the metallic blue #3340? unfortunately the decals on my model are printed in blue ink, not at all metallic. May have to mask and paint the hood blue areas myself.
Dave
Old Jul 15, 2009 | 10:16 PM
scottmoyer's Avatar
The blue decal on the hood is a match in color, not metallic. Here's what it will look like.
Old Jul 16, 2009 | 12:53 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Thanks,
Dave
daveSS1987
I have the 1982 Factory Assembly Manual Color and Trim Specification Sheet for the RPO Z50 (Indy Pace Car)
I had it all typed in and was trying to post the response when the board logged me off . The response was lost, so I will try to re-post Thur. evening. This sheet has all the WA paint codes for the body, GFX, wheels, and the WHM color codes for the Emblems and Decals.
www.stencilsandstripes.com sells the complete decal and stripe kit for about $850. Or they will sell you specific parts of the kit.
Dave
Old Jul 16, 2009 | 11:18 AM
1Aauto's Avatar
Former Sponsor
Those pace cars are cool.
Old Jul 16, 2009 | 04:29 PM
daveSS1987's Avatar
yeah especially the one they used in the race, it had an aluminum 350 instead of a 305 and from photos I've seen it had the crossfire injection.
Old Jul 18, 2009 | 12:15 AM
daveSS1987
I don't know if you saw this thread, but it has photos of 4 pace cars in it.
https://www.thirdgen.org/forums/hist...four-82-a.html
Here is the color code information......
From the 1982 Camaro Factory Assembly Manual
UPC 15D, Sheet C26
Color & Trim Specification Chart
FA00 &Z50
(&Z50 is the RPO used in the document for the 1982 Indy Pace Car)
Exterior Colors:
Body (U&L)
Silver Metallic:16* (WA-7448)
Silver Metallic:16# (WA-7736)
Accent (M)
Ultramarine Blue Metallic: 24* (WA-8273
Ultramarine Blue Metallic: 24# (WA-no number listed)
Interior Trim (Special)
Dark Blue/Silver
Stripe Package (Special)
Blue (W/Red Accent) 96A
Lower Fascias & Rocker Moldings
(Color to Match) < + + + Not sure what this means
Silver Metallic (WA-7448)
* D01 (Van Nuys, Lacquer based paint)
# D02 (Norwood, Enamel based paint, these had a different WA code))
'Blue' Stripe Color Idents.
Medium Red WMH-7251
Sliver Blue Metallic WMH-8269
Light Blue Metallic WMH-8270
Medium Blue Metallic WMH-8271
Black WMH- 848
“Z28” Emblems
(Body & Wheel Hub)
Upper Red WMH-7238
Middle Medium Red WMH-7251
Lower Red Orange WMH-7327
15” Aluminum Wheels
(14P) Silver WA-7448 < + + + It appears that Metallic was dropped here
with Red Stripe WA-4409
UPC 15D, Sheet C7
Interior Color Combination Chart
FA00 &Z50
Trim Level 3
Dark Blue Cloth (4)
(4) Front and rear seat inserts Dark Blue with Silver bolsters and side facings and Dark Blue welts.
“Z28” embroidery on head restraint to be three shades of red.
(This trim level cloth description was for L/S Conteur seats.)
General Note for all trim levels and color combinations:
All interior door armrests are Black.
W/RPO Z50, Interior door armrests are Dark Blue
This pdf file shows how the hood decals are aligned. If yo want, i can also scan and post the three sheets for the stripes around the lower body
Dave
Old Jul 18, 2009 | 07:56 AM
daveSS1987's Avatar
Great work! The decals on the hood layout is nice. looks like 3 diff decals on each side. so if the air induction doors were seperate from the decals were they black or painted blue?
Old Jul 18, 2009 | 08:36 AM
scottmoyer's Avatar
black
Old Jul 20, 2009 | 10:19 PM
Also
In the link I posted, take a close look at the third picture in message #2. You can clearly see the black color of the induction flaps.
Not quite as clearly, in message #2, second picture.
The picture Scott posted also shows black flaps, if you look very closely. No blue there
Dave
MustangBeater20
Oct 29, 2022 09:20 PM
lee01
Apr 9, 2016 01:56 PM
Linson
Aug 21, 2015 02:12 PM
87350gtanj
Aug 8, 2015 10:32 AM
