More Research - More Questions
Old May 10, 2010 | 09:14 AM
Bill4026's Avatar
Ok I found the paint code but whats the code on the bottom of the SPID?
see attached pic - Enamel WA-L7211 U7211
Still need the paint code for the black Ground Effects
Also went through the RPO decoder and need some help-
1G2AW87G6ENTRANS AM2 DR COUPE305 HO1984NORWOODPRDUCTION NUMBER 7,051 (1984) Trans Am L69 5.0 H.O. W/M5
THESE I FOUND WANDERING THE SITE AND THE INTERNET - ARE THEY CORRECTD1C4863 P CLC R CLUSTER COLOR INST, YELLOW DEVIL 1019 E 8 E A ---??????E6E6341 P SPS M SLEEVE SPEEDO (E6E) 901115 E E E A ---??????N0DNOORWOOD PLANTWS3Firebird Peformance Value Package #2 ---WHATS IN THE PACKAGE???WU1Instrument Light Shutoff Switch---?????YT1BUILD UP DR & QTR --- ?????FOR YT9 I FOUND 3 DIFFERENT EXPLANATIONSYT931824 P FLEET PROGRAM EXPOSURE INITIATIVE I: Reinforced DoorsOPTION PACKAGE, FISHER FURNISHED PARTS17CTrim Combo - CharcoalWHAT ARE THESE?BS1INSULATION, ACOUSTICAL PKGBV8ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,B20ORNAMENTATION, INTR, LUXURYB48TRIM EQUIPMENT, LUGGAGE COMPARTMENTDE1SUNSHADE, BACK WINDOWD27COVER, RR COMPT, TRUNK STOWD42SHADE, RR COMPT SECURITYMM5MERCHANDISED TRANS, MAN 5 SPD PROVISIONSVD6BUMPER PROVISIONS, FRT, ALUMINUMW62ORNAMENTATION, AERO PACKAGE
and the age old question - is it rare/special?
Old May 10, 2010 | 01:29 PM
Drew's Avatar
Re: More Research - More Questions
You might want to edit your post and format it so that it's legible. As is it's so jumbled together it's hard to follow.
If no one jumps in to help, I'll see what I can come up with after lunch.
Old May 10, 2010 | 02:01 PM
Drew's Avatar
The codes at the bottom are the actual paint codes. Enamel tells you it's enamel paint, WA is the prefix, L#### is the lower color, U#### is the upper color. 7211 is listed as Spectra Red code 75.
If you haven't already, go back to www.thirdgen.org click the rpo decoder link and run all your codes through there. Ignore any codes that say (91) at the end, as the definitions probably won't apply. Then come back here and list the ones you can't find and I'm sure we can fill in most of them. The way you have them all dumped into a paragraph with possible definitions is just a mess.
Old May 10, 2010 | 02:28 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Seems like we've got very similar cars, but in different colors.
The only "rare" options (uncommon would be more accurate) are AQ9 (Lear Siegler seats) and UQ7 (Special speaker system with two subwoofers).
WS3 must have been a Special Package grouping several "performance" options I guess. I know four different "Pontiac Excitement Plus Savings" packages of the same kind : WS1, WS3, WS5, and WS8.
This is the description of WS1 I found on a dealer sticker from an 84 S/E : "Pontiac Excitement Plus Savings : Savings with minimum purchase of : Power door locks, power windows, rear spoiler, tilt steering column and AM/FM radio with cassette"
This one is for WS5 : "Pontiac Excitement Plus Savings : Savings on minimum purchase of Hood applique, Aero Package and 5.0L 4bbl HO with performance package"
I haven't found anything about WS3 and WS8 yet.
Our cars are not really "rare", but there were only 7,051 L69 5 speed T/A built that year, add to that the L/S seats, T-Tops, W62 and UQ7 and it reduces the number of similar cars quite significantly.
Here's my SPId, as you can see I have both WS3 and WS8, but I'm not sure what this on means yet :
Could you give me your complete VIN by PM if you don't mind ? I'm making a registry of 82-84 Firebird.
I'd advise you to go to the www.earlythirdgen.com forums as we discuss mainly 82-84 Firebirds there, they are very different from the later models.
Old May 10, 2010 | 03:31 PM
Bill4026's Avatar
Thanks for the info - heres the RPO's in a better format
These I found with the decoder but am not sure what they mean-
BS1 - INSULATION, ACOUSTICAL PKG
BV8 - ORNATMENTATION EXTR DR HANDLE, LOCK CYLINDER
B20 - ORNAMENTATION INTR, LUXURY
B48 - TRIM EQUIP LUGGAGE COMPARTMENT
DE1 - SUNSHADE BACK WINDOW
D27 - COVER RR COMPT. TRUNK STOW
D42 - SHADE RRCOMPT SECURITY
MM5 - MERCHANDISED TRANS, 5SPD PROVISIONS
VD6 - BUMPER PROVISIONS, FRT, ALUMINUM
W62 - ORNAMENTATION, AERO PKG.
THESE I FOUND WANDERING THE INTERNET
D1C - 4863 P CLC R CLUSTER COLOR INST, YELLOW DEVIL 1019 E 8 E A
E6E - P SPS M SLEEVE SPEEDO (E6E) 90115 E E E A
N0D - NORWOOD PLANT
WS3 - FIREBIRD PREFORMANCE VALUE PACKAGE#2
WU1 - INSTRUMENT LIGHT SHUTOFF SWITCH
YT1 - BUILD UP DR & QTR
YT9 - I FOUND 3 DIFFERENT ONES
REINFORCED DOORS
OPTION PACKAGE FISHER FURNISHED PARTS
LASTLY ANYBODY HAVE A PAINT CODE FOR BLACK GROUND EFFECTS?
THX AGAIN EVERYBODY
Old May 11, 2010 | 01:44 PM
Thanks for giving the VIN !
BS1 - INSULATION, ACOUSTICAL PKG As stated, this is the optional acoustical insulation
BV8 - ORNATMENTATION EXTR DR HANDLE, LOCK CYLINDER It must be the black door handle and door lock (as opposed to the base birds which had them chromed)
B20 - ORNAMENTATION INTR, LUXURY Deluxe interior
B48 - TRIM EQUIP LUGGAGE COMPARTMENT This is the lockable cargo compartment, and the carpeting on the rear interior panels
DE1 - SUNSHADE BACK WINDOW This is the "stripes" on the front the rear hatch
D27 - COVER RR COMPT. TRUNK STOW Dunno
D42 - SHADE RRCOMPT SECURITY This is the rolled trunk shade
MM5 - MERCHANDISED TRANS, 5SPD PROVISIONS This is the code for the 5 speed specific parts
VD6 - BUMPER PROVISIONS, FRT, ALUMINUM As stated, front aluminium bumper
W62 - ORNAMENTATION, AERO PKG. Aero Package ground effects
N0D - NORWOOD PLANT Built in the Norwood, OH plant
WU1 - INSTRUMENT LIGHT SHUTOFF SWITCH It may be the dimming switch
REINFORCED DOORS
THX AGAIN EVERYBODY
Old May 11, 2010 | 05:41 PM
Drew's Avatar
Just to clarify...
DE1 is factory hatch louvers.
D27 is the locking cover for the hatch well.
Old May 13, 2010 | 08:47 AM
Bill4026's Avatar
THX SolarGold and Drew - but what the he** is a -
I got a bumper cover and under that is the honeycomb crush panels???
Old May 13, 2010 | 09:10 AM
yo soy el warg's Avatar
Some early 3rd gens got the aluminum bumper instead of the steel ones that attach to the honeycomb crush panels. Not too many of those around.
Old May 15, 2010 | 07:12 AM
Yes, its very light compared to the standard steel bumper. Some idiots cut some chunks of it to install a KR nose
Some 80-81 Trans Ams and Formulas had the VD6 bumper as well.
Old May 15, 2010 | 06:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, the aluminum bumper is really light, i have one in the garage. It also has a binch of large opening in it, so even less weight compared to the more solid faced steel ones. I cant imagine its very useful in a crash though
RedLeader289
Jan 22, 2016 03:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
