Underside paint color questions
Old Jul 14, 2010 | 12:36 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Dropped my rear end to put new break lines on it and decided while it was out I would restore all the other random parts back there . My qusetion is , what color would the following parts be when the car rolled out of the factory ?
Drive shaft
Torque arm
Springs
Sway bar
Sway bar hardware
I figured out some of the other parts but these have a layer of typical surface rust so I cant tell. Thanks for any info guys.
Old Jul 14, 2010 | 01:17 PM
AmorgetRS's Avatar
Re: Underside paint color questions
History & Restoration is a better place to ask this question, so I moved it there.
Old Jul 14, 2010 | 01:30 PM
Roc THIS's Avatar
Engine: 5.7 TPI
That works .
Old Jul 14, 2010 | 01:59 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Drive shaft
Torque arm
Springs
Sway bar
Sway bar hardware
Unpainted bare metal, that is why those items have so much rust.
Old Jul 14, 2010 | 02:08 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Not exactly. Most of that stuff was painted. The driveshaft and differential housing are unpainted, but most of the rest of those items are all various shades of satin/semi-gloss black. The sway bar mounting stuff may have been a zinc plated or uncoated steel as well.
Old Jul 15, 2010 | 09:58 AM
Drew's Avatar
Drive shaft - bare steel if it's not aluminum
Torque arm - Semi-gloss or 'chassis' black
Springs - semi-gloss or 'chassis' black
Sway bar - semi-gloss or 'chassis' black
Sway bar hardware - phosphate coating, looks flat black.
Old Jul 15, 2010 | 01:33 PM
Roc THIS's Avatar
Engine: 5.7 TPI
Alright thanks guys . Exactly the info I needed
Old Jul 15, 2010 | 07:39 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually there is also some markings on most of those suspension pieces as well.. They would mark with a paint pen that things were torqued. The rear diff often had yellow paint on at the point of the Universal joint where the pinion attached to the drive-shaft. There was a Green spot on the toque arm, the ends of the pan-hard arm had light blue ends...
Here is the thread https://www.thirdgen.org/forums/hist...-markings.html
I would like to point out that the rear axle was PAINTED BLACK when you had the B&W (Aussie) 9 bolt), however it was unpainted when you got the Saginaw 10 Bolt.
The Drive-shaft to the best of my knowledge was always unpainted...
Hope that helps...
John
69 Six Pack
Oct 5, 2015 07:51 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
