Help in locating the following Pontiac RPO Codes
Car: 1990 Trans Am
Transmission: Automatic
Hope that someone here can help me finding the following RPO codes. I have tried to download the RPO Decoder located here, and everything comes across all jumbled. I have all my RPO Codes, but the following:
AH3, AR9, IPC, V73, WW4, W62, Y83, 19P, 6ZW, 7ZW, 8NL, 9NL. It is for a 1990 Trans Am. Does anyone know where/how I can get these?
Thanks,
Mike
Thanks,
Mike
Community Administrator
Re: Help in locating the following Pontiac RPO Codes
The RPO decoder does work. As the RPO decoder page states, you need .NET framework installed installed or it won't work and you'll get the results you did.
Your RPO codes are fairly basic.
Y83 is Trans Am Conversion
WW4 is black Trans Am aero molding
W62 is part of the Trans Am Aero package
19P is black wheels
AH3 is 4-way manual seats
6ZW, 7ZW, 8NL, 9NL are all spring codes
You can also verify them through the follow resource, which appears to be fairly accurate when listing RPO codes:
http://compnine.com/research.php?arp...=22F&year=1990
19P is black wheels
Thanks,
Mike
Thanks,
Mike
Car: 1990 Trans Am
Thanks guy for the info. Have all now but 2. Even that compine.com site does not show RPO code IPC or V73. Anyone know where to get these 2 ?
Car: 1990 Trans Am
Was able to find the last 2 RPO Codes afterall. Thanks for the help.
Car: F-Body / Cadillac STS
Engine: 305 TPI LB9
Transmission: TH 700 R 4
hectre13
12-11-2023 08:14 AM
