What kind of belts came on your 85 Z28?
Car: 85 Z28
I was in the parts store yesterday to pick up a new alternator, water pump and belts for my 85 Z28. The guy handed me a set of V-belts and an alternator with a V-belt pulley. I told him that my alternator used a 5-rib belt, but the rest of them were V-belts. He couldn't find anything like that listed for an 85 (Carquest). Do I have the factory setup or did a PO change my pulleys?
Re: What kind of belts came on your 85 Z28?
The belt style was changed sometime during the 1985
model year-early '85s are all v-belt while later '85s
have the 5-rib for the alternator.
If the parts store cannot identify the belt,just ask for a
belt for an '86 or '87-they have the same setup.
BTW i noticed the'85 iroc with 4.3 mi. had the
early all-v belt setup.
To the best of my knowledge 82-85 are all pretty much the same, V-belts. 86 uses the same accessories with V-belts for everything except the alternator which uses a serpentine. 87 switched from the SI alternator to the CS alternator, but kept the mixed V-serpentine belts. 88-up have the serpentine setup with a single belt for everything. If the V-belt/serpentine setup with the SI alternator was used on some 85's I wouldn't be surprised.
Guest
Posts: n/a
They used the 5 rib belt on higher amp alternators, that would cover the TPI cars in 85 for the entire year. I bought my 85 from the original owner (who did not modify anything at all on the car) and it had the 5 rib, also was looking at an 8k mile 85 about 10 or so years ago and same story, TPI, high amp alt, 5 rib belt.
Car: 85 Z28
Thanks very much for the quick replies. It helps a lot. One last question, what's the rating for a "high-amp" alternator for an 85?
for the alternator ratings on v8 '85s with original
alternators that i have examined,this is what i have seen
-carb v8s with a/c and belt drive fan:66 or 78 amp 12SI
-carb v8 with electric fan(L69) 94 amp 12SI
-TPI v8-108 amp 15 SI
Never examined one,but base model,non-A/C v8s might
have a 42 12SI
have a 42 12SI
1 Post
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
I've got the 5 rib belt on my alt/crank/water pump too, mine squeals aswell even though its a newer belt and as tight as i can make it... I blame Napa :P
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
yeah all 85 tpi's had a 5 rib alt belt and 108amp alt.
I have seen a few very early '85 TPIs,probably made in
sept.or oct.of 1984,that had the v-belts-the same deep
-groove alternator pulley that was used on the LU5 and
L69 was used on this app too
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I don't believe the belt was the same length in '87. The newer style alt also used a different upper mounting bracket that tucked the alt in closer to the motor.
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
