just decoded my VIN says my Z28 is a Berlinetta
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
The fifth digit is S. The decoders list that as berlinetta. Is my car a clone or is there something I don't know.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Re: WTF? just decoded my VIN says my Z28 is a Berlinetta
VIN says Berlinetta, as would the dash...
Car: 1984 Z28 T-TOP
Is the "S" possibly for T-tops?
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Nope, 84-86
Some decoders will crunch the check digit and tell you if the VIN is valid. That's one way you can verify that you're reading the VIN correctly. If the 5th digit is really a S, then the car is a Berlinetta. You could look for other VIN's on the car, you might be able to find a partial VIN that may help you verify what you have. Really if you strip a Z28 to the shell, and a Berlinetta to the shell, you can build both cars up to be like the other with the right parts. You can look for parts that indicate it's one or the other, but they aren't concrete. Much the same, the console cover/armrest could have been swapped.
The LU5 was Z28 only. Z28 also had 15" aluminum wheels, scooped hood, black horizontal striped tail lights, ground effects, leather steering wheel, shifter, e-brake handle, and full analog instrumentation.
The Berlinetta had standard gold trim (Gold Berlinetta emblems, gold horizontal striped tail lights, Gold 14x7 aluminum wheels), V6 or 305 4bbl engine, no ground effects, plastic steering wheel, shift ****, ebrake handle, and digital instruments with a pillar mounted cassette radio. It also had some other stuff that was unique to the Berlinetta, but I'm not sure it's worth mentioning.
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: just decoded my VIN says my Z28 is a Berlinetta
check the tag right in front of the radiator, it will say Z28 right there if it is one
Car: 1984 Z28 T-TOP
Found out the vin on my car is a P. Its a Z28 afterall. I was using my insurance card to check the vin. Turns out they had the VIN wrong. Thank God!!!!! I own a Z28!!
manifoldsrme
09-17-2015 11:40 PM
