UQ7 Speaker System
Old Feb 10, 2011 | 07:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
UQ7 Speaker System
Finally found a guy to restore my 25yr.old UQ7 sound system,it feels good putting something so original to the car back where it belongs,
Hope it last 25 more years
Old Feb 12, 2011 | 09:08 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Re: UQ7 Speaker System
Which system was the UQ7? I know my firebird came with the factory subwoofer and "gain" controls, but ages ago the car was broken into and the original dash stereo was stolen. My father then replaced that factory AM/FM/Cassette/Auto Seek radio with an aftermarket removable AM/FM cassette...which was later replaced with a removable faceplate design, and then an aftermarket removable sony cd player. None of those systems would power the factory subwoofer, which i was always disappointed in.
Old Feb 12, 2011 | 10:50 AM
mantaguy's Avatar
Engine: 5.0 EFI
That's the one,when your dad changed the radio he probably didn't use the the original plug for the stock radio.If he did, it could be the gain switch itself.I did replace mine years ago.Had a real hard time looking for someone to do these speakers for me,tried Delco,to replace them,discontinued,GM discontinued, and all the radio repair shops said they couldn't find the right cones.Finally found a guy that had some really old stock cones.
Old Feb 12, 2011 | 11:34 AM
85f-bird's Avatar
Engine: 2.8L, LS1
Awesome man, good luck. There's no going back for me as of now...i recently stripped the interior back down to redo, but i did a 4th gen dash/console/door swap years ago...so unless i go scrounging around for lots of really old parts again, i have a feeling i'll never see a 3rd gen dash in this car ever again...i'm only kinda sad about that.
Old Feb 12, 2011 | 12:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yep!! Once their gone,their gone.
Old Feb 13, 2011 | 06:39 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Great ! I would love to ear the sound of this system as it was originally !
I'm doing something similar, all but the amplifier and the harness were gone in my car. Even the speakers boxes...
So I've found the original UU6 radio, added an auxiliary input to it, and I will replace the speakers with newer ones, but finding brand new 5" subwoofers is VERY difficult.
Do you know the output of the amplifier ?
Old Feb 13, 2011 | 09:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
No I don't,but it does sound pretty good.I really didn't restore them for the sound witch was a great sound for that time,I did it because that's what belongs there,
I am the original owner and it was always kept with original GM parts,but the parts are very hard to find now,so the only option is to restore what you have,if possible.
Old Jul 5, 2011 | 08:31 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
In case anyone is looking for a replacement 5" woofer, the Dayton Audio RS125-8 may be a good option. I measured the resistance of my factory sub (7.7Ω) and the Dayton speaker states that it measures 5.86Ω. This may be a close enough match to let the factory amp work with this speaker. Since I am using an aftermarket amp, I bought the 4Ω version of these speakers, but I have not installed them yet. I plan to add a 2 way crossover and have the 5" woofer play from 125 Hz to 500Hz and then a 4"x6" play anything higher than 500Hz.
The factory setup (as seen in my '84 Firebird service manual) has two 10Ω 5" woofers connected in parallel to the amplifier in the dash. The amplifier has a low-pass cutoff of 500 Hz. The factory woofer frame is 5" at the widest parts near the mounting holes and about 4.625" between the mounting holes. It has a cutout diameter of 4". The cone is 3.25" with 0.5" of foam all around. It has a mounting depth of about 2.25". I have no way of measuring the T/S parameters which are needed to find an optimum replacement.
Old Jul 5, 2011 | 09:12 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Subwoofer can be hooked up with an aftermarket radio, but you might need to hook up a relay. I did it with my wifes car.
I did it last summer so its a bit foggy... IIRC The subwoofer amp is controlled similarly to how the power antenna is switched. There is a powered wire that comes out of many radios that you can hook into the factory harness to control the power antenna, if you use this wire to switch on the amp it should work. In the case of my wifes 87 I had to use a relay because the power out of the radio was not enough to actually allow the amp to stay on it would act erratically, so I used switched power that comes into the radio thru the relay to power the amp... I want to think that the sound is from the rear speakers... It was not bad to do once I figured it out, so it is not impossible...
Sounds ok... Not horrible not terrific...
Old Aug 7, 2016 | 10:36 PM
austin_1138's Avatar
Quote:" had to use a relay because the power out of the radio was not enough to actually allow the amp to stay on it would act erratically, so I used switched power that comes into the radio thru the relay to power the amp".
I know its been six years after you've done the job, but could I bother you to give a image of your wiring? my gta has the uq7 setup but the aftermarket deck doesnt trigger the amp.
Old Aug 10, 2016 | 08:23 PM
okfoz's Avatar
I actually didn't remember doing this until I read this. More or less. on the back of the radio, connect a relay to the switched power from the radio, and then use a power connection from the car to run the amp. Typical Relay setup.
All you need is the 4 wires
1- goes to ground
1 - comes out of the radio to control the relay
1 - power from battery, I think I probably used power from the cigarette lighter or something similar
1 - power TO the amp.
John
Old Jan 25, 2018 | 07:19 AM
GTAjim697's Avatar
Car: 1987 GTA LB9/MM5 DD9 Paddle Mirrors
Engine: 305 LB9
If anyone sees this, as of 1/25/18 Someone on eBay is selling 4x4 10 ohm speakers that are the correct subs for the UQ7. Just bought 2 they have 6 left. $16 each.
Old Jan 26, 2018 | 11:31 AM
mantaguy's Avatar
Engine: 5.0 EFI
https://www.ebay.com/itm/New-Old-Sto....c100033.m2042
Thanks for the link, but they don't look like our subs, wrong P/N and our subs have the harness's connected to them and our magnets are huge.
Old Jan 26, 2018 | 02:17 PM
GTAjim697's Avatar
Engine: 305 LB9
What is the correct part number? I've been looking everywhere. My speakers were shot and not rebuildable. Bought some 4 ohm mids from parts direct, and they didn't work, impedance was too low.
Old Jan 26, 2018 | 03:05 PM
mantaguy's Avatar
Engine: 5.0 EFI
From 85-88 The P/N was 16040892,84 had a different no.Those are all discontinued.I had mine rebuilt at a shop in Pennsauken,not too far from you.Their is a member here t/aws61985 he has a nice thread on rebuilding them.I have a spare set that needs rebuilding.
Old Jan 26, 2018 | 03:33 PM
GTAjim697's Avatar
Engine: 305 LB9
Is there any impedance stamped on the back? I didn’t see any on the set that had come out of my 87. I don’t think I have them anymore.
your right the magnets do look smaller.
Old Jan 26, 2018 | 04:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
No, no Ohm markings.
Old Jan 27, 2018 | 03:24 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I went over the rebuild of mine here.
https://www.thirdgen.org/forums/memb...ml#post6017367
Old May 19, 2019 | 10:54 PM
Eighty8firebird's Avatar
Hi Dave,
I was curious if you had a link for the speaker foam?
TIA,
Greg
Old May 21, 2019 | 09:55 PM
DynoDave43's Avatar
Sure do Greg.
Speakerworks.com
Old May 21, 2019 | 11:19 PM
Sure do Greg.
Speakerworks.com
Thank you!
Old May 24, 2019 | 11:01 PM
DynoDave43's Avatar
Let the thumping bass of Performance Sound begin!
Old May 28, 2019 | 11:32 AM
okfoz's Avatar
I had a friend with one of these systems new, and he said the factory system actually sounded really good in the day, then someone stole the car, took the radio and the speakers, and even as replacement parts were used from GM, as it was around 1988, it never sounded the same.
John
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
84 TA NV
Sep 6, 2015 08:02 PM
