Is it rare?
Old Jun 2, 2011 | 11:55 AM
Mpaul3355's Avatar
Is it rare?
Ok so I'm new to this form and iv been looking for a camaro project for the longest time (about a year) money's been tight so working with limited guns this kid I know has a 91 or 92 camaro with a 350 with ttops and a 5 speed in it now I think somewhere I read that a camaro with a 350 with ttops or a 350 with 5 speed is a factory freek but this has both is it true that's it's rare but if not it needs a cluch and it's only running on 7 cylinders( if any one knows why it might be only running on 7 cylinders please let me know ) and it's in primer it suposible has 48,xxx on clock and he wants 700 for it is it worth it with the work it needs please let me know! This might be my future
Old Jun 2, 2011 | 12:33 PM
luvmy64's Avatar
Re: Is it rare?
First, you need to verify that it is a 350, not a 305. Chevrolet NEVER made a 350 with a 5 speed. If it is, in fact, a 350, then either the motor or the trans has been swapped. Run the vin number, and check the numbers on the back drivers side of the block.
Old Jun 2, 2011 | 12:40 PM
Mpaul3355's Avatar
Re: Is it rare?
I guess the rpo codes or vin would be the way to go and even if the motor was swapped is it wort it for 700 $ runnin with 7 cyl and bad cluch he says it doesnt go in any gear wht could that be ?
Old Jun 2, 2011 | 12:43 PM
luvmy64's Avatar
Re: Is it rare?
Even if the clutch is shot, you still should be able to go through the gears, i think. I would be suspicious that the trans needs a rebuild.
Old Jun 2, 2011 | 12:53 PM
Mpaul3355's Avatar
Re: Is it rare?
Ok so this thing might need some work and if so is it worth it to rebuild t5 I heard there supp. to be a good tranny and any luck with know why only 7 cyl and like I said the big question is is it worth the money
Old Jun 2, 2011 | 03:20 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Is it rare?
If the body is nice and straight, 700 is probably a pretty good deal even with the mechanical problems.
Old Jun 2, 2011 | 10:47 PM
puma1552's Avatar
Re: Is it rare?
7 cylinders, wasted tranny, wasted clutch, wasted body, surely wasted interior and wiring for that wasted motor, because nobody ever cares about the interior.
I also bet the motor has 48k, not the body.
Sounds like yet another thirdgen pile of junk, I'd pass. No, it's not rare, it's a motor-swapped pile that will probably never be worth more than $700 unless someone comes along with $20k to put into it and has a reason to do so.
Old Jun 3, 2011 | 01:24 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: Is it rare?
I paid $600 for my black 91 z-28. It's hard top, 5 speed, G92 with factory 3:42. When I bought it, the original 305 was blown and it needed paint (still does lol). If the body is in good shape and the interior is ok, just look for rust on the body ,under the car and under the carpet. If there is no rust or minimal surface rust then I say it's worth it. If it is a "project car" the buy it. Work on her when the money comes and make it something your proud of.
Old Jun 3, 2011 | 07:16 PM
Mpaul3355's Avatar
Re: Is it rare?
That's what's u was thinking
Old Jun 3, 2011 | 08:57 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Is it rare?
1) No 350 Camaros with a 5 speed were made/sold
2) No T-top 350 camaros after 1989 Model Yearl
3) Plenty of 305/M5/T-top cars out there, probably what it is... If it is a Factory T-top then it would not be a G92 for 90-92
John
Old Jun 7, 2011 | 06:09 AM
DrexRS's Avatar
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
Re: Is it rare?
Im pretty sure it didnt come stock with a 350 its probabley been swapped. And 700 is too much what he is asking with that money you can get a little reliable car, talk him down to 500
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
sjorgens
Oct 1, 2015 07:54 PM
