Body Plate Decode Help Needed
Old Jun 7, 2011 | 04:03 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
I need help decoding my body plate ID tag. I have no idead how to do it.
Please Help
Old Jun 7, 2011 | 06:09 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: Body Plate Decode Help Needed
if anyone has any idea please help or email me at 71Gonzo71@comcast.net
Old Jun 7, 2011 | 10:15 PM
Drew's Avatar
The body tags really don't tell you much... In this case it tells you the color(s) and that it has t-tops. I could grab a book and decode it, but it's not going to tell you anything you don't already know. The VIN will tell you a lot more.
Old Jun 8, 2011 | 01:07 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
C = 1982 model year
06A = built first week of June
1FP87 = 2 door coupe, Camaro
L = Van Nuys, CA assembly plant
170601 = body sequence number, should match last six digits of VIN.
18N = dark charcoal custom vinyl interior
16L = silver metallic lower body color
16u = silver metallic upper body color
W = water base paint
AR9 = Luxury bucket seats
CC1 = Hatch roof with glass panels
D, B, = unknown but believed to have something to do with installed options such as rear defog or rear spoiler
034692 = unknown, had something to do with internal tracking at the assembly plant.
Old Jun 8, 2011 | 02:17 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
thanks i appreciate it
Old Jun 8, 2011 | 09:45 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
http://www.gmmediaarchive.com/?page=ordform
Im trying to do this and im confused on what to put for trim and paint number because there is 2 paint numbers and i dont know what to put for division series. please help look at the bottom where it says body plate info. thanks
Old Jun 8, 2011 | 09:48 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Look carefully. It says you can upload your body plate image.
Old Jun 8, 2011 | 09:51 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
for some reason it wont take mine. says it wont except the file type so i saved it as another but it still wont take it
Old Jun 9, 2011 | 09:33 PM
cs2000's Avatar
Most of the body plate info is easy to decode, except the bottom letters "D" and "B", these were option codes that the Van Nuys Plant used on early 3rd gen cars, The "D" was to indicated that the car was destined to have the rear spoiler RPO D80 as the car moved down the assembly line., The "B'' is kind of a mystery, I've read in the past that this would indicate the car had the luggage compartment trim option RPO B48, that included the rear compartment cover and carpeted trim on the side covers of the rear hatch, this code should be on all Berlinettas, as it was standard on the Berlinetta and optional on sport coupes and Z28's. Other codes would be "W' for the rear wiper option and "S" which is maybe for the Stereo radio accomodation package. and the lower numbers on the plate were used to ID the body as it moved down the line, it is decoded as follows, The first two digits indicate the date the body was started down the line, 03, would indicate third day of the month, In your cars case, it would have been June 03, 1982, the following numbers "4692" is the body sequence numbers. if anybody else could shed some light on the Van Nuys options codes, I'd like to hear from you..
Old Jun 12, 2011 | 10:26 AM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Looks like you did your homework
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
