Third tank and averaging 17.47mpg
Car: 1985 IROC
I am pretty impressed with the it. The first tank I got 16.25 the second tank we are at 17.47.
What do you guys average on your stock cars?
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: Third tank and averaging 17.47mpg
What kind of driving did that include, city/highway-wise? How you liking the car compared to your 2nd Gen?
Car: 1985 IROC
The 2nd gen was much smoother ride, but the 2nd gen was way too soft. Lots of room in the 2nd gen. But the 3rd is laid out much better.
2nd gen felt HEAVY! 3rd gen feel like a feather and extremely fast.
My 80 had 3:42 gears also on 225 70 15. ran out of breath by 4200 rpm.
85 literally rips to 5500rpm and feels like more is there. GM did a great job getting the most out of a 305.
my 80 would chirp 2nd gear shifts, 85 spins the tires and slide sideways shifting into second on new Goodyear HP's.
2nd gen was much quieter inside, 3rd gen has lots of road noise.
2nd gen feels like a cow around corners, 3rd gen feels like a slot car.
my 80 was never wrecked and had original paint, fit and finish sucked!
85 fit and finish is 200% better and feels rock solid.
last night while replacing the tranny mount I could have eaten off the bottom. uncluttered and everything looked like it had its place.
80 I felt like i was riding on it, the 85 i feel like I am part of it.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I am the original owner of my 305 TPI, 5 speed car. I did not keep records over the first 10 years but I have averaged 17 MPG for the last 10. This dipped to a low point about a year ago when my fuel injectors were dying. After I replaced them, the car came right back to the 17 MPG mark. On long trips (300-500 miles and mostly interstate roads) I get 24-25 MPG.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
With similar driving, my 86 305 TPI TA gets about 1 MPG better with lousy 2.77 gears. My 350 88 IROC gets a little over 20 MPG per tank, and my 5 speed TPI 88 TA has gotten as high as 24 MPG with more open road driving (but not solid highway)...
Dallas all city driving, mixed tollway blast for 12 miles stretchs at 70-80mph in general just city.
Many people don't realize how good these cars are until they actually own one. Re: Third tank and averaging 17.47mpg
Just imagine if we were running real gas instead of the oxygenated junk. Florida is trying to repeal the requirements for ethanol. I saw a 2mpg drop with my truck using this garbage and the Camaro ran so much better before the requirement. My best was 22 with the IROC-Z. During the Hot Rod Power Tour, I was lucky to get 19/20 highway at 70. Granted the windows were down the entire trip putting drag on the car, but I believe the issue is more related to the gas!
Bottom line is, when I drive my 86, it doesn't FEEL anywhere near 25 years old. I honestly think the non-t-top cars hold up better over time, and feel better when compared to a new car, than the t-top cars. There is no way in hell that today ANY OEM would allow cars out the door that squeaked and rattled like t-top third gens do. It really dates the feel of them.
I agree about the T-Tops. While they look great and have a function, the hardtop cars feel tighter and don't make as much noise. Third Gens might not look and feel like modern cars, but they have a simple and focused intimacy about them that you just don't seem to get with cars today.
Car: 1985 IROC
Haha. You know, I really like 1st Gens. I've driven and been in a few, but wow, do they feel like the simplest, lowest tech thing ever LOL. They seem downright dangerous to be driving fast. A Third compared to that feels like it was developed in a different century and made strictly for performance. It's really just the progression that happens with each passing Gen of the car obviously, but Thirds are like right in the middle, not too high tech and not too low tech. There are many things about them that were definitely ahead of their time in the 80s though.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Car: 87 Camaro
I was getting 25 highway over the summer with my stock E4ME carb and 305. Now that it's winter I'm getting 19-22
Car: 1985 IROC
Car: 87 Camaro
I would assume winter gasoline mix as well as my choke being non functional until this morning when I adjusted it. Hopefully it'll go back up next spring.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Most cars get worse gas mileage in the cold because warm up time is longer so if it has a carb the choke is on longer or if its fuel injection the mixture is richer longer.
Winter mix is also a part of it. I can tell they already switched cause my DD gas mileage fell a good amount as did my sisters.
Car: '89 Trans Am
Transmission: 700 R4
Car: '89 Trans Am
I get around 17.2 with mixed city/highway driving. And by highway driving, I mean cruising at 80 - 90. Not too bad for a 23 year old car.
Car: tta drophead coupe, 91 form 1LE
Engine: lc2, lb9
Transmission: 2004r, mm5
Axle/Gears: 3.27, 3.45
I often wonder what fuel mileage advantage you gain by a lower gear ratio. sure the engine is going slower, but you are still pushing the same car. I used to try driving in 3rd gear instead of overdrive to see what difference in mileage I got, but I never did a whole tank so I don't know the outcome.
Lots of the newer feeling of these compared to 1st gen is the tire technology. When I was in high school, my daily driver was a 67 goat, with 14" redline bias ply and rallye 1 wheels. you could turn the wheel to take an exit, and the front wheels would slide rather than allow the car to get off the road. Just for fun, I put a set of gaudy gold Ronal R9 wheels with Pirelli P Zero tires on that car. The wheels looked ridiculous. But they made that car handle so well it was incredible. Now, they gripped so much that they wouldn't let go. the car rolled over so steep that it felt like it would tip over like a sailboat. But, it didn't slide anymore. You could place that car anywhere on the road at any speed. it took getting used to about the pitching and rolling though, and it was hard to stay on the seat. But, my point is that the tires were what was keeping that car from handling. I went way overboard on tires of course. Probably 14" radials would have been better for that old suspension. But it was interesting to see what happens when the tires outgun the car by such a huge margin.
Car: 1989 Firebird Formula
Engine: 5.7 LS1
L98 averages 17.5-18 MPG depending on my driving thats mixed with highway and just town driving.
Car: '84 Z28
Engine: L69
'84 L69/Auto here. I'm getting 12 to 13 mpg mostly city driving. The magic number seems to be only 177 miles on a tank. I think I have a carb problem.
Car: 1985 IROC
City Driving I think you benefit from from 342 to 411 gear as it take less throttle and pump shot to get going. On highways gears it takes lots of initial tip in and pump shot to get going. vice verso and highway but you relate to RPM rather than tip in or pump shot.
YIKES, what gears?
My '89 FI 2.8 Camaro got that too...frankly, my 2.8 got the worst mileage of the 6 third gens I've owned. All of my V8 cars have routinely recorded higher mileage than that car got when it was my DD 10 years ago. The BEST tank I ever got was 23 MPG, doing nothing but highway driving. Otherwise, it was always in the 16-18 range.
Car: 1985 IROC
Went up again in the wet and rainy weather we had. Beats me, why?
EDIT as my statement answered the my question. Wet rainy weather keep me of the loud pedal.
By scotiapilot at 2011-12-16
I swear, I wound the living **** outta that little 2.8 and prayed all 135 mighty HP would keep me alive. Needless to say, those 11-12 seconds going 0-60+ were the longest of my week, every week.
As much as I loved that car, I honestly do not miss it much at all. It was just too, too slow...
Car: 1985 IROC
Its funny you mention that. I remember back 12 years or so ago, I used to date a girl that lived a couple hours from me. As part of the route to visit her, I had to enter a road with a 65 speed limit from a dead stop. It was a crowded, busy highway.
WHat happened to her? Was it worth it?
Lord no...we dated for a little while, but I was 20 years old and crazy...she was just crazy
Interestingly, while I far prefer third gens, its a fourth gen that's been with me for nearly 11 years. 2 failed relationships, 1 good one, 4 jobs, 4 different addresses...its followed me everywhere, and been a damn good car
I doubt it will ever leave my garage, however, if it leaves I have room for another third gen
Black t-top Formula 350, or hunter green GTA 5 speed, anyone??
Its funny that while I loved IROCs and ignored TAs growing up, now its the Firebirds I covet more...
That's because you've had alot of Camaros and now have the actual one you always wanted, you're just gravitating to other things.
I definitely hear you on the 2.8 LOL. Goodness, they're so slow from a stop, it's just unbelieveable because you have to really plan your move out onto a busy street with one haha.
Car: 88 Firebird
Engine: 305 TBI
If I do all highway I can average between 27-29mpg. Thats with 5.0 TBI, auto, 2.73 rear end and doing about 75.
Conversely, it would be nice if my 86 had some more guts to it, and if my 88 TA was a GTA I probably wouldn't complain, even though I prefer my black wheels to GTA's gold ones
However, for what I have them for (88 for a trailer queen that's a blast to drive, and the 86 for a 3-5k mile a year weekend driver thats nice and comfy with the base suspension and no t-tops rattling away), they're perfect.The red TA may get replaced ultimately for a GTA 5 speed or Formula 350, but at this point I doubt it. The 86 is just perfect for what I do with it, so I don't foresee ever getting rid of it, really...
Engine: 5.7 LS1
What do you get straight hwy?
YIKES, what gears?
YIKES, what gears?
Car: 1985 IROC
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i get a consistent 18 mpg average. on the interstate i get 22mpg with the cruise set at 65
Bohemian
Aug 15, 2017 05:11 PM
