Any value in these?
Old Dec 13, 2011 | 07:38 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Any value in these?
I pulled off a pair of original Bilstien-Delco rear shocks off my 87 IROC and replaced them with Koni's. The driver side is blown, the passenger side is still ok. I know Bilstien will rebuild these shocks if someone wanted to have that done. Is there is any value in these to a collector? I just don't want to junk them in case someone out there might be looking for a set.
Old Dec 13, 2011 | 11:05 AM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Re: Any value in these?
I have a pair so I'd be interested in hearing the answer also. For being on the car so long they didn't feel that much different than the pair that replaced them.
Old Dec 13, 2011 | 11:48 AM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I too have an original set of Delco/Bilsteins from my 85 IROC-Z that I was planning on removing this spring for some new ones. The back end of the Camaro right now is very bouncy.
So if they are valuable to anybody, Ill save mine for them!
Old Dec 13, 2011 | 01:20 PM
cerberus's Avatar
Car: 1985 IROC
So thats what those are. I was thinking my PO replaced mine with aftermarket. They sure are pretty. LOL
Mine seem to work well.
Old Dec 13, 2011 | 02:32 PM
Engine: L98 5.7
With 30k I can see why! Mine were fair at 140k!
Old Dec 13, 2011 | 02:59 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Yes Bilstein shocks was one of the unique items of the IROC-Z package.
Old Dec 13, 2011 | 03:27 PM
Engine: L98 5.7
Were they front/rear in yellow or rear only?
Old Dec 13, 2011 | 03:31 PM
cerberus's Avatar
Car: 1985 IROC
Rear only, (i am researching now) fronts are struts, I wonder who made the front struts and cartridges
Old Dec 13, 2011 | 03:35 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Front struts were just plain black Delcos, but the rear shocks were yellow Delco Bilsteins. Around 87 or so the rear Bilsteins changed from yellow to black.
Old Dec 13, 2011 | 05:06 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
They were always called modified MacPherson struts, which were black. The Bilstein shocks on my 87 are yellow.
Old Dec 13, 2011 | 07:39 PM
Engine: L98 5.7
The stock rear bilstiens on both my 88's are yellow..
Old Dec 13, 2011 | 07:43 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Ok maybe its my imagination then, or I had some mis-information, but I thought I heard or read that the Bilsteins ended up being black towards the final years of the IROC-Z era.
Sorry about that folks.
Old Dec 13, 2011 | 07:55 PM
Engine: L98 5.7
No worries.....maybe late 89 or 90.....just stating what I have!
Old Dec 14, 2011 | 01:22 PM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Here's my 85 IROC shock.
Old Dec 16, 2011 | 05:50 PM
Andre#4's Avatar
Car: tta drophead coupe, 91 form 1LE
Engine: lc2, lb9
Transmission: 2004r, mm5
Axle/Gears: 3.27, 3.45
Was the delco name just badge engineering on a regular bilstein shock, or did delco have some special specs for the delco/bilstein? (I remember when Honda put their name on an Isuzu, and dodge on mitsubishi.)
Are these the same as the shocks that bilstein sells new today?
Old Dec 16, 2011 | 09:32 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
They were slightly modified with Delco specs, according to period road tests. Indeed, 88 has yellow ones, as mine on the IROC are yellow. I wonder why Pontiac didn't get them as well...my 88 WS6 car obviously does not have them...
Old Dec 16, 2011 | 09:39 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Yellow on my '85 and black on my '89.
