87 TA hood insulation
Old Feb 2, 2012 | 09:03 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Does anyone know where I could get the factory hood insulation or at least the part number so I can try to find it? I know it's discontinued but maybe I can find some NOS.
Old Feb 3, 2012 | 03:51 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 87 TA hood insulation
Good luck finding that,the P/N is 14099508.I picked up a aftermarket one from Classic Ind.
Old Feb 3, 2012 | 06:16 PM
NCGuy68's Avatar
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
I have a NOS Camaro hood insulator. How is it different compaired to the Birds?
Attached Thumbnails 87 TA hood insulation-pb230099.jpg   87 TA hood insulation-pb230101.jpg
Old Feb 4, 2012 | 10:49 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
How does it look? I've thought about getting one myself.
Old Feb 4, 2012 | 02:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
This is from Classic,perfect fit,no cutting,holes are already punched.looks good if you ask me.
Old Feb 4, 2012 | 08:45 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Looks good to me too. Is that the original paint under your hood? Is sure is clean.
Old Feb 4, 2012 | 09:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes it's the original paint,I always clean under the hood when I detail the car.
Old Feb 6, 2012 | 07:07 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the part number. I thought it would be impossible to find. The Camaro one is definitely different. I too have the one from Classic Industries, it is OK but I don't like the cutouts in the center that serve no purpose. I am not sure what those are about & Classic isn't sure either.
I didn't like the real thick gray one so REM the manufacturer cut me one in 1/2" with the black side showing.
Old Feb 6, 2012 | 07:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Your not supposed to remove the cutouts that are not needed.their there because of the different types of hoods.
Old Feb 6, 2012 | 07:34 PM
82tarecaro's Avatar
How did you go about this? I would like the darker side showing also.
Old Feb 13, 2012 | 08:40 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I looked up the manufacturer REM on the net and called them & told them my problems with the color & that it is too thick. They offered to make me a new one in the 1/2" material & do a reverse stamp so the black side shows.
To refer to the previous comment I know enough not to punch out the cut outs I don't need! I was just saying I wish they weren't there so it would look more stock.
Old Apr 5, 2012 | 02:42 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I received mine today from 1A-Auto, its also made by REM. I've got the Ford yellow injectors in my car, and they're more "ticky" than I care for, so I'm hoping this thick insulation will muffle that a bit.
Old Apr 5, 2012 | 03:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
Hows it look,got a pic
Old Apr 5, 2012 | 03:50 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Don't think I've ever seen a hood spring painted body color.. clean underhood for sure.
Old Apr 5, 2012 | 04:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
That spring came off a Red 88TA and it was painted red.so I guess they were painted,I don't remember if the old one was white,I'm pretty sure it was.
Old Apr 5, 2012 | 06:00 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
No offense to 1AAuto, as they have been very good to me over the years...but their hood insulator sucks IMO. The area covering the cutout for the fresh air hoods is a little TOO cut out...meaning it fell right out of mine when I opened the package.
Not cool. Why can't anyone make a decent, OEM-looking hood insulator? Here's to being thankful my IROC one is flawless after all these years...
Old Apr 6, 2012 | 11:36 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
1A's is made by REM Automotive just like everyone else's. I think it's like buying carpet, it's all made by the same company, just a different seller.
Manta, I'm about to pick up some new fasteners, the local Advance only had two packs, so they had to get some from another store. Hopefully I'll have it on this evening, if I do I'll take a pic. I put my new GM hood/cowl weatherstrip on yesterday, Modern Day only had a few left.
Old Apr 6, 2012 | 11:44 AM
82tarecaro's Avatar
I took advice from a member here and had mine custom cut with the inside facing out. It is a solid black color and looks much better then the raw insulation. I also had it cut from thinner material so that it didn't look too thick. I haven't installed it yet as my car is still in paint prison, but it seems like it should look good when installed. I ordered it through here -
http://www.fbodystore.com/servlet/StoreFront
I will see if I can post a pic of it later.
Old Apr 6, 2012 | 12:49 PM
mantaguy's Avatar
Engine: 5.0 EFI
I think my original was raw looking.It turned all black and sh!##y over the years.
Old Apr 6, 2012 | 02:16 PM
82tarecaro's Avatar
Mine was falling apart when I got the car, and it probably started out raw looking. But the black side looks so much cleaner, that it was worth it to me to make it less original and more clean. The hood insulation on later models like my TTA is molded and solid black, and it looks so much better then the early insulation.
This is the original hood insulator on my TTA. I bought the REM insulation for my 82 TA.
Old Apr 6, 2012 | 03:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Looks good 82,you got a White one too,very nice.
TTOP350's Avatar
I do know 87 and up are silver cad type plating. No idea on the older ones. I also know most of the service replacements are black in color..
Old Apr 6, 2012 | 03:15 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well I opened my package and mine appears to be 1/2" thick with the black side facing down. Maybe they're making them all that way now?
I'll try to get it installed this evening with a pic.
Old Apr 6, 2012 | 03:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
I found out that the the spring is White on my 86,and I asked a member on here with a White 86TA if his is White and it is and I asked my neighbor about his red TA(that's the guy I got the 88 from) he said he never painted the spring he had it for 13 yrs.So I guess they are painted to the body color.
Old Apr 6, 2012 | 03:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
I just checked my hood insulationI put it on upside dawn
Old Apr 6, 2012 | 03:35 PM
TTOP350's Avatar
I wonder if the 2 diff plants did it diff ways??
I only have 8 cars, 1-87, 3-89s,4-91-2s for reference and a mag artical that actually pointed out the spring. They are all org paint cars and silver springs.
Not trying to start a war but just trying to find out when they switched.
Old Apr 6, 2012 | 03:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Mine is a Norwood car,I'm looking at 82s pic and it appears to be a light color.Don't get me wrong I did paint it White,but that's because the one I replaced was.I'm the original owner and I never painted the old one.I think I still have it,I have to check it out I want it to be correct!!
Old Apr 6, 2012 | 03:50 PM
TTOP350's Avatar
Yeah every 89 TTA i have seen is silver.
BTW: if anyone needs a NOS 1st design formula hood blanket I have some. They are pricey tho!!!!! 200$ each
Old Apr 6, 2012 | 04:23 PM
82tarecaro's Avatar
Mantaguy - it looks right. I don't think the fasteners would have lined up if it was upside down. When I ordered mine, the guy from Fbodystore told me that the later ones were made with the black side out to more closely match the original. The earlier ones looked like raw insulation so that is the side they face out.
Old Apr 6, 2012 | 04:26 PM
82tarecaro's Avatar
TTOP350 - not that pricey considering they aren't available anymore.
Old Apr 6, 2012 | 06:56 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well I have a pic of mine but Photobucket isn't wanting to work today. I'll try to post it again later.
Old Nov 1, 2013 | 09:41 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
I know this is an old thread, but this is EXACTLY why I put one on my car. PO removed.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
