trying to find out if i have a GTA
Old Mar 1, 2012 | 01:29 PM
91Zconvert's Avatar
Car: 91 Z28 ragtop, 88 SS monte
Transmission: auto
is there something in the vin or any other way to find out if my trans am is a GTA?
1g2FW 21F1K L2490 16
Old Mar 1, 2012 | 01:31 PM
AmorgetRS's Avatar
Re: trying to find out if i have a GTA
From the VIN you cannot tell if you have a GTA.
Outside of the SPID sheet it is basically impossible to tell as parts can be swapped.
Also, check out the GTA Source Pages authentication tips: http://www.gtasourcepage.com/newauthentication.html
Old Mar 1, 2012 | 03:34 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
SPID sticker will tell for certain, but 1989 GTA isn't that easy to copy if you check out the GTAsourcepage.
TPI, no vent fenders, and steering wheel with radio controls is too much trouble to copy for what these things are worth if it isn't a real GTA.
Old Mar 1, 2012 | 04:21 PM
AmorgetRS's Avatar
TPI was available on the Trans Am. Fenders without vents are very easy to come by and if the GTA had a CD Player stock, the steering wheel wouldn't have the controls from the factory. If you don't have the SPID there is no way in knowing what it came with from the factory.
However, on a whole, you are correct, but the SPID is the only end all be all way of knowing.
Old Mar 1, 2012 | 10:29 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
The standard items on a GTA were also options on a T/A.
As Amorget is hinting at, you need to check the SPID sheet. You are looking for the Y84 code.
If you don't have the SPID, for Canadian cars, you can run the VIN at your local GM dealership. For US cars, it is very hit and miss. Canada maintained the records from 1980 on. In the US, it was somewhat based on whether or not the dealership participated as there are two different systems for tracking the info (this was told to me by the GM guys here in Canada). The last option is to then visit gtasourcepage.com to look for authentication tips, as already mentioned.
Old Mar 1, 2012 | 10:36 PM
y-84ta's Avatar
Car: 83 camaro
Engine: 355
Transmission: th350
You could look for the build sheet
Old Mar 2, 2012 | 10:52 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Does the car have rear disc brakes? That's one quick way to rule it out since WS6 was standard on all GTA's (assuming someone hasn't swapped the rear-end).
Old Mar 2, 2012 | 10:24 PM
Starbug's Avatar
Car: '89 Firebird Trans Am WS6 - project
Engine: Building a 400 C.I. SB Chevy V8
Transmission: manual T5
Axle/Gears: posi rear end
I wouldn't think that would be a good way to know for sure. I have an '89 WS6 Trans Am that is fully loaded with every GTA option. However, it's clearly badged as a Trans Am, has no gold accents, and it has the front fender vents.
GTA's must have (from gtasourcepage.com):
  • gold center tail light bird
  • gold "PONTIAC" in the driver's side headlight turn signal
  • no front fender vents
  • gold 16" diamond-spoke aluminum wheels
  • Ultima seats
  • the dash pocket should have a gold "GTA" or bird on it, never "Trans Am"
  • All years had a leather-wrapped steering wheel. '87 had "GTA" on the horn, '88 had the stereo controls mounted in the steering wheel.
  • GTA badges on the nose, front fender (where the Trans Am's fender vent is), and a GTA bird on the sail panel.
  • TPI engine only
Obviously, things like steering wheels, seats, TPI engines, and front fenders can be replaced over the years due to the original part being wrecked in an accident, worn out, or a previous owner didn't like it. A SPID sticker will confirm a real GTA. Look for the Y84 code.
Old Mar 2, 2012 | 10:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
How about PHS,Pontiac Historical Service.
Old Mar 3, 2012 | 03:57 AM
91Zconvert's Avatar
Transmission: auto
thanks everyone.i found out it wasn't a GTA.
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
gta power
Aug 13, 2015 06:15 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
