'86 IROC. "Full Resto".
Transmission: World Class T-5
Axle/Gears: BW 3.45
Says, $50K invested. Looks nice, but I totally hate those hillbilly tailpipes and would have preferred stock wheels
http://cgi.ebay.com/ebaymotors/1986-...item27c49919b3
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: '86 IROC. "Full Resto".
Tail pipes dont bother me as much as the wheels and the interior. If they are going to go through that much trouble dont skimp on the interior. That does not even look close to factory from those pictures. Looks all velour plush-like. Im assuming it had a carmine red custom cloth interior from the factory judging by the seat pattern the upholster tried to copy. Person should have done some research and found you could still get factory seat material if you look hard enough.
Aside from that....i think its a pretty nice car.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Is the interior really that bad? I dont see the problem with it?
I really hate the wheels. Chrome IROCs are bad enough in 17+ inch versions, but that's excusable since nonchrome/aluminum IROCs just arent available above stock size. But in 16 inch versions where there's nice looking factory aluminum wheels available, I dont see what the point is of putting those gaudy chrome wheels on it. Some people just love tacky chrome garbage all over their cars I guess.
Car: 1985 IROC
I think a guy with no knowledge or skill could easily pay 50K to have everybody else do work on a car. SADLY
Seats are fugly ODO being changed...whats with that
Wheels blow
Wheels blow
Axle/Gears: BW 3.45
Those seats do look pretty velour-y. Anyway, not everything is correct on this car, but it's nice to see people actually doing a nut and bolt rotisserie on a 3rd gen.
Engine: LS1, LB9, L03
Yep. Those chrome 16's are so ugly that they look like chrome 15's. Nice of them to tamper with the odometer for the next owner...that's not going to look so great if the car has had any Carfax records in the last 5 years or so.
I think if I spent $50k on a 3rd gen, I'd have replaced the yellowed brake fluid reservoir...
On the plus side, it's nice to see that someone finally did a nut and bolt restoration on a 3rd gen. If this guy really wants to sell this car, he's realistically looking at more like $10k...I'd still take an original, low-mileage car before this one though.
Engine: 4++,350 & 305 CIs
Its a very nice "restification" but its not a restoration. There is sooo many little things wrong with it, mostly finishes of nuts/bolts/clips/braces and the complete painting of the frontend under the fenders. The master cyl and reservoir(yellowed and no code sticker) sticks out like a sore thumb to me.
Its a very very nice "restified" car but not 50k nice.
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
This car isnt terrible, but not perfect. Right off the bat:
-Wrong/ugly wheels
-Old engine bay parts
-eBay chinese rice parking lights
-old tail light lenses
-newer fog light surround
-80s Cadillac bench seat velour leftovers.
However it is nice to see the IROC-Z door stickers in their correct locations for once.
Axle/Gears: BW 3.45
Right - there are paints available that replicate the e-coat. It would have looked like more attention was paid to the details. They should have sprayed undercoat where it was applied from the factory also.
But do we even know what the underbody finish was from the factory? All I've seen is that there's debate as to whether it's actually paint or more like a sealer, probably leaning towards the latter but IIRC nobody really knows what it is.
Axle/Gears: BW 3.45
But....like I said, it's nice to see people going to this level of effort on a 3rd gen "restoration".
Axle/Gears: BW 3.45
Hold on, I'll be right back..............
Axle/Gears: BW 3.45
Just took these. Whether this is paint or sealer, this is what a factory underbody is colored. Kind of a low gloss gray.
Sure, but wouldn't we want the paint code for it? It could just be uncleared paint, but something tells me it's not. I remember a debate about it a while back but I don't think we were able to decipher exactly what the factory used, or how best to replicate it.
Sure you could take some gray paint and try and get it close and it would look quite good, but still it wouldn't really be correct. I am a huge fan of painting the entire undercarriage personally.
The gray is from the dip tank that all these cars bodies went thru before they got painted.
The fenders, frt/rear impact bumpers, doors, hood and front core support were all bolted to the car before paint. The mirrors, hatch and (firebird) headlight lids I'm still not sure of. the bumper covers wings and ground FX were painted off site.
I'm fairly sure that all the cars got under coating in all 4 wheel wells and on the bottom of the spare tire well from the factory. floorpans, tq arm(yeah), driveshaft(yup seen that also) were dealer items..
What kind of undercoat did they use? It seems to be more like a truck bed coating because it is not flexible and gooey like the dealer applied stuff.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If it's on a rotisserie, it wouldn't be that difficult to at least make an attempt to make it look original underneath. Paint it that dull grey. And then don't mask it off when it gets the real colour.
And on this particular car, it's difficult to tell just from the pictures, but it looks to me like the underbody had some rust in the usual areas before it was painted. The rear unibody "subframe" doesn't look nearly as smooth as it would on a known, perfect, babied, unrestored car.
I just looked at the Ebay add for the car. I don't know about you guys n gals but I'd like a cotter pin in my lower A armball joint.
The car is very nicely done but not correct for a restoration.
Axle/Gears: BW 3.45
It looks like my black IROC had some panels which started out blue. While touching up tiny stone chips on the passenger fender, ground effects and rear spoiler (which I actually had to have repainted 20-ish years ago), there is IROC blue under there.......
Axle/Gears: BW 3.45
Funny you say that, because on the 1st repaint on my black 89 formula I found that the scoop in the hood was completly red under the factory black paint ! That was the only part like that.
Car: 1985 IROC
Where were they built? My original owner said Van Nuys line was notorious for letting ill fitting parts stay on cars while other lines were told to swap parts until they fit/
Well its a 89 so I guess it was built on the left coast because of the paint falling off in sheets and it has a body color cowl panel. When did they stop norwood cars? 87ish??
Supposedly the TTAs were done in batches because they were getting other paint colors under the hood when they were on the line as they went through the paint process. Maybe that's why you have different colors on your cars?
Edit - I reread the posts and that sure wouldn't explain having a whole panel the wrong color. It would only account for overspray.
RedLeader289
May 28, 2019 01:47 PM
