Contradicting RPO codes?
I was checking through RPO codes for my 1984 Trans Am.
found that the Special Edition Recaro package was y84(which I do not have
But I also found Recaro Seats (RPO- Aq9) which I found on my RPO sheet...
It says it was only available with the Recaro T/A option. Don't believe my seats are Recaros either, but may have been swapped?
Any help?
http://www.82firebird.com/RPOLookup.aspx
Any help?
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
Re: Contradicting RPO codes?
Do you have pic of your RPO sheet you can post? or can you PM me a pic? What does your cowl tag say? The Recaro seats where only available with Recaro package.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That would be a neat find, take a pic of your SPID.
John
John
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Dumb question here but first does the vin on your code sheet match your car?
its very easy to swap the console pad,
then - as far as i know for 1984 recaro seats only came in the recaro edition, all of them had tan interior
regular seats were AR9
But i did hear of some 85's having a recaro seat option even with the recaro edition no longer being offered.
here is a pic of a recaro seat from an 82 that i swapped in my 84 trans am
My 1984 literature shows that AQ9 is "Lear Seigler" seats and was available for the Firebird, Trans Am and S/E. It shows the Recaro seats as T/A only.
However, I have two build sheets from 1984, both for Y82s. One shows AQ9 as "R/L L/SEIGLER" while the other shows AQ9 as "P/D RECARO".
Jeff, or JT.
What was the RPO for the Recaro package?
John
John
Soooo Kicking myself, I was at a junkyard, (has to be 9 years ago now) but they had a Recaro Trans Am, and it had the seats, they were trashed, but I am sure someone could have fixed them up... They were Tan.
John
John
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
RPO AQ9 was the code shared with both the multi-adjustable Lear Siegler seats and the Recaro seats.
From '82-84 RPO Y84 Black Special Edition Trans Am option would trigger the Recaro seat install. I'm not sure how it was done from '85-86 as the Recaro seat option was reduced to an interior option and was available on any color Trans Am that could be combined with a tan interior.
When the Recaro T/A disappeared, the optional Recaro seats were RPO code AS5. But that does not appear to be the case for the T/A Recaro edition as that code is not found. I see no specific code for it.
It does appear that AQ9 was shared, as evident by the build sheets for two different 1984s having two different definitions. I seem to recall a discussion about it from another member, too.
Therefore, to the OP, is it possible that you have the Lear Siegler seats and not the Recaros?
Car: 1982 Firebird Trans Am
Transmission: automatic
Hey Jeff......
Its Eric with the 82 trans am in California. I tried emailing you at 82transam@comcast.net and I tried calling you but no response. Do you mind getting back with me. I had an important question
Eric
Eric
