What was the last year for the carbureted third gens?
Old Jun 9, 2012 | 02:17 PM
JimRockford's Avatar
I was wondering what year GM stopped offering carbureted Firebirds and Camaros? I am guessing it would be around 1987 but am not sure.
I personally like the carbureted setup best for a daily driver because the fuel pump is mounted with two bolts to the side of the engine block where its easy to get at.
Old Jun 9, 2012 | 02:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What was the last year for the carbureted third gens?
The LG4 was available until 1987, but it had both a mechanical and an electric fuel pump.
Old Jun 9, 2012 | 03:11 PM
You mean it could have either a mechanical fuel pump or an electric pump right?
Why would someone want an electric fuel pump on a stock 4bbl carbed motor?
Old Jun 9, 2012 | 03:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it had both.
The electric pump charges the supply line to the mechanical pump so there are no vapour lock problems.
Old Jun 9, 2012 | 03:42 PM
Sorry for all the questions,but why in the world would they need to do that when the 1986 and earlier ones used a mechanical fuel pump? I have had several 82's and 83's and never had vapor lock problems.
So what happens on a 1987 when the electric fuel pump goes out,can the mechanical one still run the car?
Old Jun 9, 2012 | 05:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You didn't, but enough people did that there was even a dealer-installed vapour lock kit that added the electric pump and a carburetor cooling fan to earlier years.
Old Jun 9, 2012 | 05:14 PM
Thanks for the info,I never knew that. What did the carburetor fan look like? Why didnt the second generation cars have vapor lock problems?
Old Jun 9, 2012 | 05:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pictures of the installed kit have been posted before.
During the 70s cars produced less heat and had more underhood space.
Old Jun 9, 2012 | 06:55 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Old Jun 10, 2012 | 12:47 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
The L69 engines had this problem too.
Originally Posted by Apeiron
No, it had both.
Old Jun 10, 2012 | 01:25 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Lol I'd never thought I'd see someone Pretend to be Rockford other than me. '87 was the last year of the carb for the F-body
Old Jun 10, 2012 | 10:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ones that came without both pumps, yes.
Old Jun 10, 2012 | 11:45 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i found an'84 L69 that had the carb blower-the
blower had an'85 date on it,so probably dealer
added in response to customer complaint about
vapor lock.The blower was in the RH fender
behind the battery,didn't see the hose setup as
that was missing.Only the electric fan carb
cars had the blowers or boost pumps as the
older mechanical fan cars have better underhood
ventilation and less heat buildup.
BTW,i remember watching in late '89 a news
program about the last q-jet being built-i think
a few 1990 GM cars/trucks were the last q-jet
cars made.
Old Jun 12, 2012 | 01:25 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
cars made.
Yeah, IIRC, the last carbureted GM cars were the full-size 1990 Caprice/Custom Cruiser/Buick Estate wagons with the anemic Olds 307. Buick and Olds dropped their full-size RWD sedans after 1985 (and Pontiac after 1986), leaving just the Caprice as the only full-size RWD sedan in GM's lineup (other than the Cadillac Brougham, which I want to say was already TBI by 1990). The Caprice sedan went to TBI around 1987 I think.
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
st.evel07
Aug 13, 2015 06:15 PM
