trans am or SE?
Old Oct 9, 2012 | 12:51 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
trans am or SE?
so i picked up this 85 firebird for 1000 last week. I was told that it is an SE but it has trans am fenders and rims, it also has a v8 with a 4 barrel and if i ran the vin right it is suppose to have a v6. anyways, im confused and was looking for a little guidance. i tried to post pics but it wasnt working, here is the vin. 1g2fx87116fl203843.
Old Oct 9, 2012 | 02:11 AM
AmorgetRS's Avatar
Re: trans am or SE?
I am 99% sure it's an SE. The X in the 5th location denotes SE, plus it's a V6, so basically no way it's a Trans Am.
Old Oct 9, 2012 | 02:16 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
ok thats what i was thinking too. so why the v8 then? being in cali do you think i can still get it to smog if its had a motor swap?
Old Oct 9, 2012 | 02:18 AM
AmorgetRS's Avatar
Re: trans am or SE?
Why the V-8... the car is around 27 years old, a lot can happen in that time.
If the V-8 came from a 85 and newer and has all the emissions stuff, you should be able to get it to pass, but you'd be better off asking in one of the California regional boards as they will know more about getting cars past Cali emissions.
Old Oct 9, 2012 | 02:26 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
thats a good point about the age. My friend has an 84 camaro and they match perfectly as far as smog equipment goes. thanks for your help!
Old Oct 9, 2012 | 10:07 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: trans am or SE?
Yeah the TA did not come with the v6 and why would someone sway in a v8? well it is very common as most want a faster, better sounding car.
Old Oct 9, 2012 | 10:34 AM
yo soy el warg's Avatar
Re: trans am or SE?
Even though engines, interiors and wheels get swapped out guys usually don't swap out the gas filler lids on the SE. They came with a locking lid and were completely flat. I would bet that yours still has one on it.
Old Oct 9, 2012 | 11:49 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Re: trans am or SE?
'85-86 S/E's are pretty $%&* rare !!!
Old Oct 9, 2012 | 02:45 PM
92GTA's Avatar
Re: trans am or SE?
Nice! I had an '82 SE and would have loved an '85-'86 in the updated body style!
Old Oct 11, 2012 | 02:20 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
ok so something new i noticed on the car, it has a 9 bolt rear end and HUGE sway bars. it does have the locking gas cap also. did SE's ever come with 9 bolts? can that tell me anything more about the car?
Old Oct 11, 2012 | 02:21 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
how rare?
Old Oct 11, 2012 | 02:41 AM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
here is a pic of the car.
nvm it wont upload
Old Oct 11, 2012 | 02:51 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: trans am or SE?
As Long as it has the stock exhaust manifolds, and smog equipment and The catalytic converters you should be able to pass smog very easy, but just as a precaution, change the Sparkplugs oil & filters before going to get it smogged
Old Oct 11, 2012 | 02:52 AM
Phenom-1's Avatar
Engine: 5.7 TPI
Re: trans am or SE?
Take a picture and try to upload it again its easy
Old Oct 11, 2012 | 02:56 AM
Phenom-1's Avatar
Engine: 5.7 TPI
Re: trans am or SE?
Vin: 1g2fx87116fl203843
Check the Vin again, a digit is wrong somewhere because I can't find it on carfax.
Old Oct 11, 2012 | 03:32 PM
CJpearce's Avatar
Car: 85 firebird SE
Engine: LG4 5.0
Axle/Gears: 9 bolt
Re: trans am or SE?
Ok so I checked the vin again and I did have it wrong, instead of "11" its and "H" (it was at night when I wrote it down) haha.
Old Oct 13, 2012 | 03:25 AM
Phenom-1's Avatar
Engine: 5.7 TPI
Re: trans am or SE?
Still didn't work
Old Oct 13, 2012 | 04:05 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: trans am or SE?
Well if it's an H instead of the 11, then it means it came with an LG4 305 4bbl V8...
Old Oct 13, 2012 | 04:19 PM
JT's Avatar
JT
Community Administrator
Re: trans am or SE?
According to the GM VIN card for 1985, it shows that 1G2FX prefix is for Firebird S/E (X being the SE - as AmorgetRS stated above - while a W would be for a Trans Am) so that would appear to be a clear indicator.
Old Oct 14, 2012 | 07:09 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: trans am or SE?
82-86
S = Base Firebird
W = Trans Am
X = S/E (Special Edition)
87-92
S = Firebird OR formula
W = Trans Am OR GTA
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
