How many 1989 5spd lb9 convertibles?
Old May 24, 2013 | 10:24 AM
RandyKoontz's Avatar
Does anybody know how many 5spd lb9 convertible Irocs were built in '89?
Old May 24, 2013 | 06:47 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: How many 1989 5spd lb9 convertibles?
Not sure. Would be a choice item however, especially with the G92 axle.
Old May 24, 2013 | 08:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/1989-chevy-camaro
Old May 25, 2013 | 10:24 AM
Originally Posted by mantaguy
That's "wonderful", but it doesn't tell me how many rag-tops had the lb9 & the t5.
Old May 29, 2013 | 02:27 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Seeing that you did not specify Firebird or Camaro,...
I am not sure, but I do not believe the Camaro was available with the LB9/MM5/G92 in Convertible trim in 1989, I know 1987 it was however... I am sure that from 1990-1992 the convertible was NA with the LB9/MM5/G92 combination, heck you could not order a T-top car with that combo either for those years.
Firebird is Less than 25
John
Old May 30, 2013 | 07:45 AM
I'm pretty sure the car I'm looking at does not have G92, but it is an lb9/t5 car.
Old May 30, 2013 | 08:15 AM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
firebird or camaro?
Old May 30, 2013 | 11:27 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Originally Posted by IMissMy86TA
firebird or camaro?
I'd have to assume Camaro as there were no factory Firebird convertibles until 1991...
Old May 30, 2013 | 12:54 PM
okfoz's Avatar
True... Kinda... There was just over 600 Firebird Convertibles made from factory parts from 86-89 made by ASC, they had all the factory components, with factory part numbers, and in the same facility as the "Factory convertibles"... (Factory Convertibles were not made in the factory either). Nonetheless the Firebirds were Special Dealer Order cars.
Since the original poster did not specify "Factory" or not, I did not want to assume...
Old May 30, 2013 | 01:09 PM
Engine: 5.0 TPI
yeah..didnt want to correct anyone ASC is kinda psudo factory for GM.
if you look here:
https://www.thirdgen.org/1989-pontiac-firebird
you will see at the bottom convertible production figures for 89...
396....
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
89fast5oh
Sep 8, 2015 09:55 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
