Can someone please help with trim tag?
Old Jun 21, 2013 | 09:59 AM
KILLA85T/A's Avatar
Car: 1985 Trans Am
Engine: 305 4bbl(not H.O.)
These trim tags confuse the hell out of me, so many random numbers! Here's a pic of the tag. Any help would be great.
Thanks, Mike
Attached Thumbnails Can someone please help with trim tag?-100_2837-1024x682-.jpg
Old Jun 21, 2013 | 01:38 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: Can someone please help with trim tag?
on the first line
F - is the build year = 1985
01 - build month = january
A - build week = 1st week
2FS87 - body style = 2-door Coupe, All Firebirds share the same body style code
L - assembly plant = Van Nuys, California
612666 - Vin Sequence Number = Body Number, This is also the last six of the VIN
30l - Lower Body Color
30u - Upper Body Color
Water - Paint Type = Water Based Paint
AR9 is the seats
that's as much as i know for sure, i decoded it from
http://82firebird.com/DecodeCowlTag.aspx
it's for 82 -84 but much of it is the same for 85, it just didnt give me the color for your color codes
Old Jun 21, 2013 | 01:56 PM
KILLA85T/A's Avatar
Car: 1985 Trans Am
Cool thanks man! So did all under hood trim tags, Trans Am and Firebird, have the S code in the body style? I'm finding some conflicting information on my body trim tag and my actual VIN tag number.
Old Jun 22, 2013 | 12:03 AM
jez3941's Avatar
i think the body style code would be different in later years for the convertibles
as for your vin being different on the tag i am not sure of that
Old Jun 22, 2013 | 07:15 PM
JT's Avatar
JT
Community Administrator
30U and 30L are the exterior color codes for Bright Blue Metallic.
Old Jun 22, 2013 | 07:40 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
By the time the convertibles were being built, the trim tag was no longer being applied to the car with these details.
Old May 16, 2022 | 03:19 PM
waterboy5127's Avatar
Car: 1983 Z28
Engine: 2006 LQ9 cammed
Transmission: 4L65E
Axle/Gears: 3:42
I can not seem to find ANY information on decoding trim tags. Not the 1986 Post RPO codes, but the tag on the rad support, here is a pic of mine, any thoughts? Thanks
Old May 16, 2022 | 08:06 PM
Drew's Avatar
Without digging out the books, the first line are date codes and partial VIN numbers. Second line is the interior color/options, Lower and Upper paint codes. Third line has AR9 for the seats, and CC1 for ttops. 4th line says it's a Z28, with a spoiler (iirc). B18 and B33 are probably option codes.
Honestly the trim tags don't tell a lot on thirdgens, so there's not much in the way of how to decode them. A blurb in a book here, or there, occasionally on a website. Nothing on that tag is going to unlock a huge markup in collector value.
There's a chart in this book,
Amazon Amazon
if you can find a copy.
Old May 16, 2022 | 10:22 PM
JT's Avatar
JT
D = 1983 Model Year
01C = January, 3rd week build
1FP87 = Camaro
N = Norwood Assembly plant
126377 = VIN
17C = Charcoal custom cloth interior
75L = Red Lower Exterior
75U = Red Upper Exterior
E = Enamel Paint
AR9 = Seat type
CC1 - T-Tops
Z28 = Z28 Camaro
D80 = Rear Spoiler (Standard Z28)
PT = Unknown
The last lines are job sequence and scheduled dates, internal to the plant so I don't think those have any sort of decoding to us.
Old May 18, 2022 | 05:54 AM
Car: 1983 Z28
Transmission: 4L65E
Axle/Gears: 3:42
Greatly appreciate your time, Thanks.
Old May 18, 2022 | 05:58 AM
Car: 1983 Z28
Transmission: 4L65E
Axle/Gears: 3:42
Super, appreciate all the detail. Just seems strange that there is not simply a "pic" with per line item explaining these tags out there. But that explains why these forums are so important. Thanks again. I think I am going to try sending a message through the GM Heritage site on this subject, probably waste of time, but nothing ventured, nothing gained. Happy Summer (finally) all.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
