Correct cruise control lever
Old Jul 6, 2013 | 03:33 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
He everyone, I have been looking for a NOS CC lever for my 1987 Iroc. It works perfect but the white lettering is wearing off. All the CC levers I find are the later 1988-1990 ones with the lip just under the resume slider. Any ideas where to find one?
Old Jul 7, 2013 | 05:21 PM
82tarecaro's Avatar
Re: Correct cruise control lever
Why don't you just touch up the white paint? It is engraved so touching it up with some acrylic should be easy.
Old Jul 7, 2013 | 10:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
or,http://www.moderndaymuscle.com/inc/sdetail/160/14890
Modern Day should have what your looking for.
Old Jul 9, 2013 | 01:56 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Maybe for someone that does professional pinstriping...I dunno about you, but I can't perfectly paint lettering. If you know anyone, let me know, I need to replace my mirror switch for the same reason (works fine, just all of the print is gone).
Old Jul 9, 2013 | 03:08 PM
82tarecaro's Avatar
Usually with something engraved you don't have to be perfect. Put paint on it, and wipe off the excess and the paint should stay in the engraved part. Sometimes you need to let it dry a little and wipe off the excess. It's worth a try.
Old Jul 9, 2013 | 03:45 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Thanks for the responses. I don't "think" my lever has any engraving on it. But I'll check, on the other hand I cant paint worth a flip.
Old Jul 9, 2013 | 03:54 PM
82tarecaro's Avatar
I just checked the lever on my 82 TA. The outer part of the switch is engraved (the part with the cruise control function) but the middle part is not. Oddly enough, on my switch, the engraved parts are the ones that are worn. Your switch might be different.
Old Jul 11, 2013 | 04:31 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If memory serves There was 3 generations of turn signal handle... each generation had a cruise option and an option without cruise.
82-83 - Type 1, - 3 wires IIRC for cruise...
84-87 - Type 2, With cruise there was more electronics on these, and used less vacuum, - These were similar to the 82 & 83 as the went through the column, but they added a wire for the cruise control, they tended to work better than the earlier type.
88-92 - Type 3, essentially the same system as the 84-87 BUT the connector for the handle was up top in a little removable box, instead of the wire going through the column.
Do not take my word for it, but I believe that GM used the same cruise turn signal levers for every model for any particular year... The difference was some were all black (like our cars) and some had chrome pieces.
John
Old Jul 11, 2013 | 08:46 PM
puma1552's Avatar
John
Don't forget that '90-'92 were yellow print, one of which with cruise is the holy unicorn of NOS cruise control levers. Been looking for years, have seen all others except that one.
Old Jul 12, 2013 | 09:54 AM
okfoz's Avatar
I believe that the yellow lettering would have been Camaro only..
Old Jul 13, 2013 | 11:45 AM
my82roc's Avatar
Car: 89 Iroc Convertible
You can also find the yellow print levers in the 1993 4th gen camaros
Old Jul 15, 2013 | 05:10 PM
okfoz's Avatar
I am not sure if they are the same handle or not... I know that the 4th gens (at least 1995) the turn signal is on a 30° Angle verses the Horizontal 3rd Gen type... They may be, but I just do not know...
Old Jul 16, 2013 | 01:46 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I've been looking for a yellow turn signal lever for 8 years. I have yet to find one. I was thinking of contacting 1a auto to see if there is any way if getting this stuff reproduced.
Old Jul 16, 2013 | 02:21 PM
okfoz's Avatar
I would start at http://www.hawksthirdgenparts.com, he is an advertiser and has a ton of stuff...
Just checked, white only... He might have one in the yard tho...
Old Jul 16, 2013 | 03:06 PM
my82roc's Avatar
I have this one in yellow.Some slight wear on the word set
Attached Thumbnails Correct cruise control lever-img_1787.jpg   Correct cruise control lever-img_1788.jpg
Old Jul 16, 2013 | 03:26 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Great picture! Mine is White (of Course) but my 1987 does not have that ledge of plastic under the slider to resume cruise. Anybody have an NOS 1987 cruise???
Old Jul 16, 2013 | 05:17 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
What do ya know. Another cruise lever thread, and it ends with discussing the yellow one with people trying to sell theirs. Just like my cruise discussion.
cmk-2 To answer your question, they are hard to find. Depending on how patient you are, they pop up on ebay from time to time. Most I see with correct white lettering have the "fat" stalk between the washer paddle and the steering column. But like I said, I eventually found mine online. A correct GM nos part. Apologies for not knowing the part number off hand. As for the ledge under the cruise button, I am not sure. The one I have happens to have it. The rest of the stalk is correct. Good luck in your search.
Old Jul 20, 2013 | 10:39 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
John
John, both of my 89s have the wires running all the way down the column. I think 90-92 airbag cars had the connector right where the stalk snaps in and those used the thicker plastic base between the letters/ column.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
toones
Jan 6, 2016 06:00 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
