What year gauge cluster is this?
Old 10-22-2013, 11:48 PM
Pinguiclia's Avatar
Car: 1992 Camaro RS
I recently picked this out of a U-Pull it and I was curious to know what year it came from? I noticed it was a 145MPH Speedo (cable driven) and if I'm not mistaking doesn't that make it worth somewhat more?
Thanks,
Justin
Old 10-23-2013, 05:46 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Re: What year gauge cluster is this?
Looks like an 85-89 Z28, IROCZ cluster to me. I don't know if all 5 years had a cable driven speedometer though.
Old 10-23-2013, 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No 145's in 1985. Some cars, 86-89, had them. They were all cable driven in Camaros. While the 145's are more desirable, they don't typically sell for a bunch.
JamesC
Old 10-23-2013, 07:39 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
It came out of a late 1986-1989 low output 305 TPI car.
Old 10-23-2013, 08:39 AM
Pinguiclia's Avatar
Car: 1992 Camaro RS
Thanks for the help guys!
JamesC
What typically made the 145's more desirable? Is it as simple as the MPH were higher?
Old 10-23-2013, 09:14 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes, that is correct. JamesC is a thirdgen guru!!!
Old 10-23-2013, 10:07 AM
JamesC's Avatar
Yes. For example, my 85 IROC was originally equipped with an 85 mph speedo. Frankly, that was embarrassing. I swapped it out for the 145 and the high redline tach.
JamesC
Old 10-23-2013, 10:28 AM
Pinguiclia's Avatar
Car: 1992 Camaro RS
JamesC
Alright thanks for the answers, and could I get your opinion on how much it might be worth? I've done some research and I've seen some 145s go for $85 and some that go to $120+.
Old 10-31-2013, 01:22 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
JamesC
Yep, it all goes back to the myth that whatever the highest mph reading is on the speedo is the car's actual top speed. No one wants people (that believe the myth) to assume their car tops out at 85 mph when in actuality it's closer to 130-140 mph.
Old 11-01-2013, 09:10 AM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Keep in mind that from the mid 70's thru 1985 it was mandatory to have a max of 85mph speedo... (It was from one of those stupid Progressive think tanks believing that it would reduce speeding by mandating car companies to max out speedometers at 85 MPH.) So cars from 1985 it would not be correct to have a 145 speedo...
Old 11-08-2013, 11:16 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Which drove some of us to see how far we could spin/push them past the 85 mark...
Old 11-10-2013, 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That cluster came from a late 86 - 88 TPI Camaro. The lg4 & l03 cars didn't get the 145, and the 89s had the oil pressure gauge flush with the tach.
Old 11-10-2013, 08:58 AM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
The problem is that the needel hits the trip odometer reset button at about 86mph.
Frozer!!!
01-19-2024 04:55 PM
Jeremys87
07-14-2022 09:08 PM
fonzie85
08-13-2015 11:50 AM
ChevyZ71
08-13-2015 07:30 AM
Quick Reply: What year gauge cluster is this?
